What is the purpose of resistive load at line output trans?
Old 11th September 2009, 03:16 AM   #1
commstech is offline commstech  Indonesia
Default What is the purpose of resistive load at line output trans?
I am looking at some linestage with output transformer coupling. it seems that some designs incorporate a resistive load at the secondary of the linestage output transformers. eg. 600ohms , 1k etc. one example would be the AudioNote M10.
there are also plenty of designs without the resistive load at the secondary.
can anyone advise the purpose of this resistor?
Old 11th September 2009, 03:35 AM   #2
HollowState is offline HollowState  United States
HollowState's Avatar
In the schematic you have provided, and most others like it, it is to maintain the correct load impedance reflected back to the primary and plate of the output tube. This is done in case the external load is insufficient to perform the task. If you should connect an external load of the correct matching value, then a resistor is unnecessary. The resistor shown in the circuit is called a terminating resistor that can be switched in or out as needed. In the case of a tape recorder playback amplifier that has a VU meter connected across the secondary, proper termination is necessary for correct meter calibration.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 11th September 2009, 03:49 AM   #3
any method to determine if the external load is sufficient or of correct matching value & anyway to know what this value must be?
Old 11th September 2009, 04:14 AM   #4
Consulting the manufacture's specifications is the best way. In the case of a transformer coupled output like the M-10, the secondary impedance is the value to use. And the terminating resistor will (or should) match it. In this case it is 600 ohms which is standard for most professional audio line amps.
Old 11th September 2009, 05:34 PM   #5
kevinkr's Avatar
The resistor is there to provide a termination should it be required, note as well that it will reduce the gain significantly (depending on primary impedance relative to the driver tube rp) which may be its real purpose. I serviced a lot of AN stuff and indeed most of my system is transformer coupled. In just about all cases with UTC, AN and Magnequest transformers I have found it generally sounds slightly better when the transformer is driving a relatively high load impedance. (10X -100X the impedance the transformer is designed to drive) Remember we are mainly interested in voltage gain here and significant power transfer is not involved. (I have never seen an M10 where the switch was closed and the resistor was in circuit.)
Poorer quality transformers may behave and sound better with load impedances relatively close to their designed load impedance.
There should generally be no problem with running these into loads that are close to open circuit relative to the impedance the transformer is designed to drive. Note that this is not true in the case where the driver can develop appreciable power (plate voltages and current capability) sufficient to damage the transformer. I have yet to see this in my somewhat limited experience. (I run with a crowd of people who use transformer coupling extensively, although at this point I am certainly the most extreme.. )
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
What is the purpose of resistive load at line output trans?Hide this!Advertise here!
Tubes load resistance and output trans impedance Jeffy74 Tubes / Valves 4 22nd December 2012 09:53 PM
Output trans plate load question 5687 vs 5965 phrarod Tubes / Valves 0 7th June 2009 03:24 AM
Parafeed with resistive load mashaffer Tubes / Valves 9 16th September 2005 08:19 PM
Copyright ©1999-2017 diyAudio
