my third RH84
Hey everyone! Im just starting my third RH84 on an ''existing chassis'' and i've got three 9 pin sockets and one octal on a very small chassis. My power transformer has two 6.3v secondaries and no 5v, so ive been trying to think of a tube solution.
Does anyone know of a 6.3v octal FW rectifier capable of 150 or so m.a.d.c.? I have a few 6X5's but there not capable of that kinda current...
Thanks!
Hmmm... yes Akai. What a hidden gem. I've picked up many over the years just to butcher them. There dipped in wax (so no corrosion:)) and each have their own power tranny and cute little choke. Its a recipe for nice S.E. amps, and if your lucky they come with some good Matsushita EL84 's!:cool:
Since your've built two successful RH84 amps, why not try a bit of variety. The partial feedback approach works best with a high output impedance driver - so a pentode is just the job. I have had great success using a 6AU6 in similar circuits. I would be more than interested to find out if there was a noticable difference in sound quality doing it the right way.
Shoog
I've tried A triode-strapped EF86 in some experiments which sounded very nice, Plenty of gain. I've also built an amp with trioded EF804 driving 6v6's with some p2p feedback for my father-in-law with a pod dock and he seems quite pleased.
Were you using the 6au6 as a pentode? I vaguely remember a push-pull thread with some plate to plate feedback going on, was that you Shoog?
Yes I did use the 6AU6 as a pentode in two partial feedback PP amps now. As Bigwill says doing anything else defeats the object of the exercise.
The EF86 doesn't make the best candidate - you need something which will carry a standing current of at least 5mA at about 150V on the plate - this makes the 6AU6 an excellent candidate - and its dirt cheap.
Shoog
I'm interested in a 6au6 version. I'm sitting on a couple of Sony TC500 R2R's (SE 6aq5) that I was thinking of making into an RH84. But they've already got the 6au6's! They also have 6CA4 rectifiers, I was thinking of using two in parallel (I know one would do it, but two would keep the resistance a little closer to the 5U4 that is specified, and I know AK carefully optimized the circuit).
pj
www.wildburroaudio.com
If you have an amp which uses 6AU6's it should already have a screen supply so all you would need to do is work out a suitable operating point. Can you lay your hands on a schematic.
I wouldn't bother paralleling the recifiers, this circuit is very forgiving of slight variations and the lower impedance won't make a lot of difference if the power supply has a choke.
Shoog
