| diyAudio Sponsor | ||
First time I see three transformers kissing each other. It takes two to tango but what about three?
The web page shares the same philosophy, so much in so little space. http://www.diyzone.net/article.php?sid=1159 |
#2 |
Three is a crowd...
#3 |
what are these strange drawings beside pics? maybe letters?
#4 |
Its not the transformers themselves, its cages.
#5 |
One of them might be a big choke for the power supply.
#6 |
The two "front" ones are most likely the output transformers. It's a SE stereo design from the looks of it.
#7 |
If you bother to search around on that site you'll find other nice amplifiers like this one.
http://www.diyzone.net/modules.php?o...125265&forum=3
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#8 | |
Rob |
#9 |
I think the amp is based on a principle called STC - Super Triode Connection, where a triode is used in a feedback loop in a fashion that gives the OP-device, be it a tetrode, pentode or a transistor triode characteristics. Built one of those with ECL82. Works OK.
/Magnus
| Very Cool | KBK | The Lounge | 175 | 14th January 2007 07:15 PM |
| This is cool | tubelab.com | Tubes / Valves | 5 | 29th November 2006 11:29 PM |
| This Is Cool !! | valveitude | Tubes / Valves | 10 | 2nd October 2006 04:48 PM |
| Really cool! | mdlover | The Lounge | 9 | 18th November 2003 05:56 AM |
| Page generated in 0.08205 seconds (82.76% PHP - 17.24% MySQL) with 10 queries |
