pls help me, Buil my first AMP with 6H5C (=6AS7) tube. - Page 2 - diyAudio
Old 22nd October 2012, 08:03 PM   #11
artosalo's Avatar
Originally Posted by lieukiem View Post
is this Schematic ok?
No. The phase splitter ECC85 must have some +70...+85 V at the grid to bias the tube.
Old 4th December 2015, 05:20 PM   #12
BinaryMike's Avatar
Well, I stumbled upon this thread a bit late, but here's the circuit I was working on. Perveant is DC-coupled and solid-state up to the 6AS7 grids. This driver slews cleanly into positive grid territory and yields about 30W output from a pair of 6AS7s. The OPT is a $12 speaker line matching xfmr from MCM (555-7125) with nominal primary Z of 1K. It limits performance below 40~50Hz, as expected, but this amp still leaves a satisfying sonic footprint. Individual 6AS7 triodes generally don't conduct equally at low current levels, but the 22R cathode resistors enforce pretty good current sharing at high levels. I never built Perveant into a chassis, partly because of power supply complexity and partly because I tend to lose interest in many projects past the breadboard stage.
Ignore the IP notice on the schematic. This design is released into the public domain.
Make a preamp with an already buil amplifier fabinto Tubes / Valves 2 2nd August 2007 04:32 PM
6AS7 OTL mr l Tubes / Valves 7 8th March 2007 01:36 AM
6AS7 as rectifier tube? kmtang Tubes / Valves 9 6th January 2006 10:51 AM
how to buil a subwoofer madcow Car Audio 1 16th August 2004 11:32 PM
6080/6AS7/6H13C/6H5C in SE? Colt45 Tubes / Valves 8 18th November 2002 05:56 PM
Copyright ©1999-2017 diyAudio
