Posted new P-P power amp design
Old 20th July 2011, 01:23 PM   #1021
whitelabrat is offline whitelabrat  United States
whitelabrat's Avatar
@Alexontherocks: What are source are you using for your amp? Laptop?
I've found that the DCPP works with my iPod as a source but it has to be cranked to 10 for good output. I get the best result when I use a preamp or a stronger source like a discrete cd player.
Old 20th July 2011, 01:48 PM   #1022
Alexontherocks is offline Alexontherocks  Italy
I have used my ipod, a cell phone, my own laptop all maxed out but the volume on the amp is nowhere near loud as I would expect.
Music quality is excellent though.
What kind of measurments must I perform to debug the board? Is there any obvious mistake in assembly I may have made?
Thanks for the support.
Old 20th July 2011, 02:11 PM   #1023
P.s. I am using 6JN6 tubes...if the problem is overall gain (I doubt it...something is clearly wrong) is there a direct valve replacement (ie: plug and play?)
Thanks!
Old 20th July 2011, 02:17 PM   #1024
On Hiatus
SY's Avatar
Alex, it's unclear from your description whether you have a power shortage (i.e., the amp clips before reaching 15 watts) or gain shortage (with the source maxed, the amp isn't clipping but the volume is low). Could you please clarify?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 20th July 2011, 02:34 PM   #1025
The amp does not clip infact cranking the ipod output does not produce any discernible distortion.
Basically maxing out the source the volume is acceptable (on the lower side) but very sharp and free of distortion.
I believe the overall gain is lower than expected.
Old 20th July 2011, 02:51 PM   #1026
Old 20th July 2011, 05:10 PM   #1027
nightanole is offline nightanole  United States
A 6GF5 would boost gain 50% orso
Old 20th July 2011, 08:14 PM   #1028
so my problem is actually a know issue?
Is the 6FG5 tube a perfect substitute?
Alex
Old 20th July 2011, 09:57 PM   #1029
nic6paul is offline nic6paul  United States
Alex
It is a direct drop in. I have used them in my amp as well.
- Nic
Old 20th July 2011, 11:08 PM   #1030
so the gain problem is actually common to other builders?
Posted new P-P power amp designHide this!Advertise here!
Waveguide TMM Posted Zaph Multi-Way 95 5th July 2010 11:53 PM
New books posted pmillett Tubes / Valves 10 30th December 2005 01:27 PM
Vifa XG18 design posted Zaph Multi-Way 7 31st October 2005 08:02 AM
Who posted this circuit ?please help me ! thanh Solid State 2 28th September 2005 09:29 AM
Posted design for wall-mounted speaker Zaph Multi-Way 1 21st July 2005 09:43 PM
