Old 3rd September 2010, 09:41 PM   #501
vinylkid58's Avatar
Originally Posted by nic6paul View Post
I still have a full assembled board sitting here, just haven't gotten around to firing it up. I have it modified to run the 6HJ5s as well.
I just finished my board, all I have that will work are 6JM6's.
Do I need heat-sink compound for the n-channel MOSFET's? The data sheet doesn't mention anything about this.
jeff
Old 3rd September 2010, 09:53 PM   #502
rknize is online now rknize  United States
All the best stuff comes from Chian
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Compound will help thermal conduction. You don't need an insulator, though.
Old 3rd September 2010, 10:02 PM   #503
So the tab on the chassis mounted mosfets are not carrying any voltage?
**Just remembered mine are a different then the ones prescribed in the BOM. Mine are not the fullpack version If I remember correctly. It has been a while since I lasted looked in that box.
- Nic
Old 3rd September 2010, 10:04 PM   #504
bigwill is offline bigwill  United Kingdom
General Nuisance
This board is like the chevy small block of tube amps
Old 3rd September 2010, 10:25 PM   #505
vinylkid58's Avatar
Ok, thanks.
jeff
Old 4th September 2010, 12:54 AM   #506
athos56 is offline athos56  United States
athos56's Avatar
Originally Posted by pmillett View Post
If there is enough interest, I'm not adverse to spinning a version of the board that has octal sockets... and making some other changes, within reason.
Food for thought...
Pete
I would buy 2..
Old 4th September 2010, 01:14 AM   #507
tubelab.com's Avatar
If your mosfets have a metal tab, ASSUME that it is hot with voltage. It usually is. The mosfets that are totally encased in plastic are safe to use without an insulator. If you can get any rading with an ohm meter from the metal tab to board ground, an insulator is needed.
Hey, I'm a Mopar guy! But I will admit to tweaking a 350 or two, and even a 5.0, but the only V8 I currently own displaces 446 CI (a .030 over 440) and makes well over 500 HP.
With a little hot rodding (a hot cam and headers maybe) any of the 17 watt tubes can do 40 to 50 WPC.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 4th September 2010, 02:02 AM   #508
rknize's Avatar
Right sorry. If you used the described part it doesn't need an insulator. If it has a metal tab, it needs to be insulated with a pad or mica+grease.
Old 4th September 2010, 02:02 AM   #509
rsumperl's Avatar
As long as we're talking Mopars..... I worked for Chrysler in Highland Park in the radio design group back in the mid 80's. Been a Mopar fan since. My toy is a 93 Sundance with a 3.8L V6 from a 2003 van. Heads are ported and polished, nitrous, and 5 spd from a 2003 Stratus w/the 2.7L V6. ECM has been custom calibrated. Exhaust feeds a catalytic, then straight back. Pipe size is 2 1/2".
Old 4th September 2010, 02:08 AM   #510
rknize's Avatar
I got 60WPC out of the "little" 6JN6's, but that was pushing B+ to 500V. At a more sane 450V, 40-50WPC should be a piece of cake. Very early in this thread, Pete mentioned that he had also tried higher voltages but opted back off in the name of hobbyist success rate (and probably reduced mortality rate).
Waveguide TMM Posted Zaph Multi-Way 95 5th July 2010 11:53 PM
New books posted pmillett Tubes / Valves 10 30th December 2005 01:27 PM
Vifa XG18 design posted Zaph Multi-Way 7 31st October 2005 08:02 AM
Who posted this circuit ?please help me ! thanh Solid State 2 28th September 2005 09:29 AM
Posted design for wall-mounted speaker Zaph Multi-Way 1 21st July 2005 09:43 PM
Copyright ©1999-2013 diyAudio
