Posted new P-P power amp design - Page 137 - diyAudio
Old 10th September 2012, 06:22 PM   #1361
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Hey Ben
Looking good, you will have plenty of time to complete your board as Edcor tend to take a while on the transformers.....
Where are you planning to get your socket from?? I got mine from these guys Pacific T.V. - Vacuum Tube Sockets hassle free
What sort of case are you planning?
Cheers
If you keep digging in the garden of failure you will eventually find success
Old 11th September 2012, 03:41 PM   #1362
Originally Posted by Dagwood View Post
Hey Ben
Cheers
I also have a Millett MOSFET-MAX to complete as well, so I'll be turning towards that little guy soon. Not sure where I'll get the sockets, there are a number of sources. Antique Electronics Supply is in Tempe, AZ and I'm just next door in Mesa, so I might stop by there and check them out.
I am planning a custom case. I've got some RTiA5's in Cherry from Polk Audio, and I'm thinking of pairing this amp with some RTiA1 or A3's. That being the case, I'd try and mimic some of the design elements, the curved cherry wood finish.
Old 5th October 2012, 03:45 PM   #1363
Well, the MOSFET-MAX is almost complete, just waiting for a couple hardware pieces to complete the case.
However, my Edcor transformers have arrive and they are beautiful. They still smelled of the lacquer paint. So, I can switch back into my "Engineer's Amp" mode. I guess I need to design the case to get started with some of the remaining bits and pieces.
Old 7th October 2012, 08:23 AM   #1364
Dagwood's Avatar
So many projects...so little time! The story of my life!
Keep us posted ( with pics as well )
Old 25th October 2012, 03:49 PM   #1365
Got my Edcor transformers. They are beautiful.
I have also finished my MOSFET-MAX with good results.
Now, I'm back in research mode. Looking for a suitable preamp for my engineer's amp and sketching up some design ideas for the case.
Old 25th October 2012, 04:25 PM   #1366
tomlang is offline tomlang  United States
tomlang's Avatar
I'm in the final throes of building a remote controlled line tube preamp utilizing the 6EJ7 for tone control duty as shown in the most recent 4th edition of Morgan Jones. I can share details if you are interested but you may cringe at the thought of tone controls...
Old 25th October 2012, 11:17 PM   #1367
vinylkid58's Avatar
Very cute! What cans are you driving with that?
Same here.
jeff
Old 26th October 2012, 08:16 PM   #1368
rudrud is offline rudrud  Finland
Default Mains transformator
Thanks for the forum! Many useful. Question.
Can I use EDCOR XPWR 205 (300-50-0-50-300) 200mA & (3,15-3,15) 6A without changing the schema?
Thank you.
Old 26th October 2012, 08:58 PM   #1369
Default Mains transformer
Question II
Can I use Hammond 370 HX (275-50-0-275) 230mA (3,15-0-3,15) 6A
372 HX (300-50-0-300) 230mA (3,15-0-3,15) 6A
Which is better?
73!
Old 29th October 2012, 04:48 AM   #1370
A few years ago I discovered the Conn organ amp that used 7027 output tubes. The power transformer is the ultimate in simplicity: 2 black wires 2 red wires and 2 green wires; plus a white wire for the ground shield. The filament winding is easily capable of handling 4x 6550s plus another 1.5 amps for the front end; the power winding is of course a voltage doubler type; quite comfortable running 1200 uF filter caps, and providing about 460 V to the plates. The output iron features 4-8-16 ohm output taps and gives the Citation 5 a SERIOUS run for its money. Vintage Conn Organ 2 Channel Tube Amp Amplifier from Deluxe Theater Organ | eBay (got it for $95) You have to get a second one to get two outputs; this one completes my set so happy bidding!
Waveguide TMM Posted Zaph Multi-Way 95 5th July 2010 11:53 PM
New books posted pmillett Tubes / Valves 10 30th December 2005 01:27 PM
Vifa XG18 design posted Zaph Multi-Way 7 31st October 2005 08:02 AM
Who posted this circuit ?please help me ! thanh Solid State 2 28th September 2005 09:29 AM
Posted design for wall-mounted speaker Zaph Multi-Way 1 21st July 2005 09:43 PM
Copyright 1999-2017 diyAudio
