Posted new P-P power amp design - Page 11 - diyAudio
Old 6th October 2009, 03:40 AM   #101
Geek's Avatar
Heya Jeff,
Originally Posted by vinylkid58 View Post
Old school integrated, not the greatest schem: http://www.triodeel.com/eist70ps.gif
Looks like decent iron?
Ooooookay, one of them things... 7591... yeah, 6K6 OPT.
Thanks for the info
Cheers!
Old 6th October 2009, 06:32 AM   #102
pchw is offline pchw  United States
I have a fully restored Eico ST-70 with some recommended enhancements from David Gillespie. I can say the irons are indeed quite decent. These 2 are from another ST-70 that I picked up from a garage sale.
Since these OPT don't have UL tap, this amp from Pete and Miles 6BQ6GTB/807 pentode are my final choices. Pete's PCB makes the build a lot easier, but the 6BQ6GTB and the 807 tube are close to the 7591 which are the OPT was designed for. Tough choice.
- Fred -
Last edited by pchw; 6th October 2009 at 06:45 AM. Reason: I meant 6BQ6GTB, not 6BG6.
Old 6th October 2009, 09:37 PM   #103
Geek's Avatar
Hi Fred,
Originally Posted by pchw View Post
...but the 6BQ6GTB and the 807 tube are close to the 7591 which are the OPT was designed for. Tough choice.
I know the 806 likes much as the 6L6 family does, but I thought Miles was using 4400 ohms A-A for his 6BQ6 beauty?
Cheers!
Old 7th October 2009, 01:53 AM   #104
Miles Prower's Avatar
Originally Posted by Geek View Post
Hi Fred,I know the 806 likes much as the 6L6 family does
Huh? I guess you must have meant 807 there. The 806 is something much different.
That's what it does use: 4K4 (P-2-P). Given the plate characteristics, a 6K6 (P-2-P) would put you way down on the characteristic, and away from the most linear part. 6K6 would probably be more apropos to much higher voltages and Class B or Class C for an RF amp.
There was one Portugese (Brazilian?) deisgn for an AM plate modulator that got 70W of audio from a PP pair of 6BQ6GTBs, but it was deep into Class AB, and definitely not designed with sonic excellence in mind (which is not legal on the ham bands anyway).
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 7th October 2009, 05:54 AM   #105
Geek's Avatar
My bad... my brain was two tabs over from when I posted
Now I have some 4.3K-ish Dynaco iron here, I can play with your design some
Cheers!
Old 7th October 2009, 06:06 AM   #106
Bummer, but I do have a pair original Dynaco ST-70 OPT's that are .... 4.3K P-2-P? If so, I am still in the game
- Fred -
Old 7th October 2009, 08:24 AM   #107
Geek's Avatar
Yes you are!
PP isn't squeamish about being loaded heavier.
Just go for lower voltage, more current and stay outta deep class-AB and you'll do 4.3K fine.
Cheers!
Old 7th October 2009, 02:34 PM   #108
whitelabrat's Avatar
I'm trying to keep costs down. Would I be able to get away with a 820pf X5F ceramic instead of mica? I would expect that this has an anti-RF application and an X5F may not do well over 10Mhz?
Old 7th October 2009, 03:30 PM   #109
pmillett's Avatar
I would expect the ceramic would do fine. I put the caps there because there was some tendency to oscillate if the OPT leads were very long - not sure exactly what the FB path was. Also tended to optimize the square wave response and damp any ringing. You may not even need them...
Pete
Old 8th October 2009, 02:53 AM   #110
Tubelab_com's Avatar
I can't find any 10uF 500v electrolytics .... I have a 47uF 500v Panasonic that seems to fit.....Scratch that. The 47uf is a 450v, not 500v
862-6216 100uF 500V $2.31 Still shows 17 in stock, but I ordered 10 this morning.
I got these today, they are tall and skinny, and they fit the board just fine. Unfortunately, now they are all sold out!
862-6214 82uF 500V $2.03
I got some of these too, but they are short and fat and cover up some surrounding components. They will work in a low profile version of the Simple P-P which is why I got them. I didn't order any other caps this time.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Waveguide TMM Posted Zaph Multi-Way 95 5th July 2010 11:53 PM
New books posted pmillett Tubes / Valves 10 30th December 2005 01:27 PM
Vifa XG18 design posted Zaph Multi-Way 7 31st October 2005 08:02 AM
Who posted this circuit ?please help me ! thanh Solid State 2 28th September 2005 09:29 AM
Posted design for wall-mounted speaker Zaph Multi-Way 1 21st July 2005 09:43 PM
Copyright 1999-2017 diyAudio
