diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Cathode follower Class A output stage? (http://www.diyaudio.com/forums/tubes-valves/15118-cathode-follower-class-output-stage.html)
Circlotron 14th May 2003 02:36 AM
Can anyone point me toward some stuff dealing with cathode follower class A type output stages? I imagine these would have some unique properties over more common type of o/p stage.
316a 14th May 2003 08:32 AM
CF
Hello ,
I've been pondering over something similar using 7236/5998a and mains toroids as output trannies which should work rather well . Driver stage is the main hiccup !
316a
pedroskova 14th May 2003 11:32 AM
Anthony Dockrill had an article in Valve discussing a 10Y driving a parafed CF 6L6GC in tetrode mode. No longer up on the web, but I could email you the pdf.
he discusses it a little here...
http://www.audioasylum.com/forums/tu...sages/530.html
Circlotron 14th May 2003 11:48 AM
Re: CF
Originally posted by 316a
Hello ,
I've been pondering over something similar using 7236/5998a and mains toroids as output trannies which should work rather well . Driver stage is the main hiccup ! 316a
Hi 316a. Driver stage - yeah, it's gotta swing lots of volts doesn't it? Maybe bootstrapping it's dc rail from the output tube cathode would help. I assume you would use a parafeed setup when you use a toroid as an output tranny - it won't give very good bass response with dc flowing through it. There is no airgap in the core. Uhh, actually did you mean single ended or push pull class A? :scratch: You just gotta post the results when you get it going, ok?
pedroskova, that would be good if you would email me the pdf. Thank you. :) Thanks for the link too.
316a 14th May 2003 12:08 PM
Toroids
Push pull works fine with toroid outputs , DC cancels . Working on a toroid amp at present but not a CF one , remember the 'power' long tailed pair output stage I posted a while back ?
316a
Ryder 14th May 2003 12:27 PM
cathode follower ops
Circlotron 14th May 2003 02:13 PM
Re: Toroids
Working on a toroid amp at present but not a CF one , remember the 'power' long tailed pair output stage I posted a while back ? 316a
This one? http://www.diyaudio.com/forums/showt...895#post125895
316a 14th May 2003 02:22 PM
Power long tail
That's the chap ! But I'll be using a depletion mosfet instead
316a
Circlotron 14th May 2003 03:08 PM
Here you go then -> gpratt@alphalink*com*au
Just change the asterisks to dots.
Brett 14th May 2003 03:59 PM
Re: Toroids
316a
I built a 12E1 PP using an almost identical biassing scheme. Op points were 240Va-k, 120mA/tube, -34V , 5ka-a using a battery biassed 820 on a big sink. Got about 12W out of it. Took it apart to use the PS components in something else, as it was a bit hard on the chokes I had at the time. Sounded very good for a lash-up.
Which depletion mode MOS are you going to use? The DN2450?
Cheers
Resources saved on this page: MySQL 18.75%
