Cathode follower Class A output stage?
Old 14th May 2003, 04:09 PM   #11
316a is offline 316a  England
316a's Avatar
Default Depletion Mosfets
Hello ,
I'll be using a simple DN2540 first then a cascode with a 2540 TO220 and TO92 . Like the 'hot'n'low' opearting point for 12E1 !
316a
Old 14th May 2003, 09:35 PM   #12
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
interesting to say-old geezers from old books use to say that triode like to see at least 3Ra even if load is cathode connected.
that's why CFs are most linear when they are CCS loaded.
I pay that price once-when I was brave enough to put 600:600 xformer in cathode
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th May 2003, 11:49 PM   #13
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default CFs...getting fed up.
There's a small raft of different CFs out there but either way it's hard to make a "Joe Average CF" more linear than it is already.
Oh well not all CSSs are made equal either...
A CCS will linearise virtually any circuit...whether you like the result or not is an other issue altogether...
Making generalisations like that is not going to help you nor anyone else...
Frank
Old 15th May 2003, 01:06 PM   #14
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Originally posted by pedroskova
Anthony Dockrill had an article in Valve discussing a 10Y driving a parafed CF 6L6GC in tetrode mode. No longer up on the web, but I could email you the pdf.
Got it. Thanks. Interesting that he refers to it as tetrode mode but it is really in triode mode because the cathode is moving up and down while the plate and screen are staying put, i.e. plate and screen are doing the same thing. For tetrode mode, the screen should move up and down with the cathode but at a fixed voltage above it, while the plate stays still. Only read that recently, didn't realise it mysef until then.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 15th May 2003, 11:11 PM   #15
Zen Mod's Avatar
Default Re: CFs...getting fed up.
interesting-most apealing way to make any stage in tube amp or preamp (for me,off course) is to use single triode and xformer,hehe-in any order you want or can;
I know that is not best way in any case,but I just like sound made with lotsa iron
accent was on right Rload,not on CCS.I like CCS in heater circ,but I realy don't bother much with implementation of same in cathode or anode.
but,what is important-is good to know and try various ways in achieving to make good stage.
(that's why I asked for some schmtc )
for me seems that more important are some other things for good stage.like operating point,slew rate,etc etc are;
in fact ,I almost hate most of SRPP designs,even real CCS loaded-I can't say much more except that sound made in that way is sorta boring
be well!
Cathode follower Class A output stage?Hide this!Advertise here!
Cathode Bypass in a PP Output Stage CLS Tubes / Valves 8 15th July 2008 05:32 AM
U-Follower: Output from Cathode or Plate? sgerus Tubes / Valves 5 23rd May 2007 08:30 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
cathode bypass in PP output stage? RichJones Tubes / Valves 23 31st October 2003 09:30 PM
Cathode follower driver stage Joel Tubes / Valves 23 16th November 2002 06:55 PM
Copyright ©1999-2017 diyAudio
