Can I use this output transformers with a 5965?
Old 6th September 2009, 02:47 AM   #11
BudP is offline BudP  United States
BudP's Avatar
Hi Poinz,
Back when I was being "forced" to learn how to design outputs for tubes, in 1974 when tubes were dead, I was told to add the Plate resistance, either one I calculated, or one given in mhos and shown as transconductance, in parallel with the load line. This, added to the DCR of the primary and the square of the turns ratio times the secondary DCR, would give me a figure for primary reactance. Dividing that number by two pi and the frequency of interest would give me the primary inductance I needed, out in the power band, to support a - 3db power output at that frequency of interest. Multiplying that number by 2.76 provides a -0.5 db power output.
In SE OPT's there can be resistors in the plate to ground path that occasionally swamp the Rp and then they become the Rp. Please understand that my education was at the hands of practical transformer engineers who wanted something close to an ideal answer, but due to the +/- 25% nature of E/I core permeability, worrying about the last bit of refinement was not acceptable.
I am always willing to learn better methods.
Can I use this output transformers with a 5965?Hide this!Advertise here!
Output trans plate load question 5687 vs 5965 phrarod Tubes / Valves 0 7th June 2009 02:24 AM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
12AV7- 5965 Vs 12AY7 Trout Tubes / Valves 25 4th September 2008 09:31 PM
page Eli Duttman's Simple p-p with 5965 MQ EXO-173 and 6AQ5 Norris Wilson Tubes / Valves 25 15th August 2008 07:58 PM
