#51 |
Oh, I understand!
To use only one panel meter with limited (1Meg) resistance to metering bias and another voltage, not an easy task. Switching panel meter (on/off) surely will modify bias point, unless driving resistance not enough low. |
#52 |
Theoretically if you use (circa) 100mA current source (from 90V supply) and 500R potmeter, then moderately (high) voltage divider, 1Meg switching on/off only affect operating point below 1% (0.66).
#53 | |
Thanks for your help, I'm learning a lot with this! Cheers, ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp) http://www.bartola.co.uk/valves/ |
| wm-61 measuring mic | nukaidee | Multi-Way | 55 | 25th March 2009 11:44 PM |
| how is it measuring? | fumihiko | Digital Source | 18 | 24th January 2005 04:10 PM |
| Measuring Le | thatvan | Multi-Way | 6 | 29th October 2004 10:09 PM |
| Measuring fT and hFE? | capslock | Solid State | 6 | 23rd September 2003 03:50 PM |
| Easy ways of measuring output impedance of tube stages | stigla | Tubes / Valves | 4 | 16th May 2003 11:37 AM |
