diyAudio Sponsor
Old 2nd September 2009, 11:15 PM   #1
Default Triode connected Pentodes in a cathode bias?
I have a Crate V3112 with 4-el84's. I was thinking about doing this for that amp. I've read that the plate volts can be bad for the screens, but I've measured only about 4 volts difference between them on this amp, so I don't see what the problem is.
I would connect them with the 100 ohm screen resistor in the middle.
What do you think?
Old 2nd September 2009, 11:31 PM   #2
leadbelly's Avatar
What's the B+ supply to the plates?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 2nd September 2009, 11:38 PM   #3
328-333 volts depending on the time of day.
Old 3rd September 2009, 12:30 PM   #4
leadbelly's Avatar
300 is the limit for the EL84 screens. I wouldn't try it myself.
Old 3rd September 2009, 10:11 PM   #5
Merlinb is offline Merlinb  United Kingdom
What do you think?
With 100R screen resistors that is fine. Many people have done it. As you point out, there is hardly any difference in voltage in either mode.
Cathode bias 6LU8 UL/Triode mashaffer Tubes / Valves 2 29th September 2008 10:37 AM
Cathode bias 6LU8 UL/Triode mashaffer Tubes / Valves 0 28th September 2008 11:45 PM
Pentodes, triode mode and grid screen dissipation 101 duderduderini Tubes / Valves 3 22nd September 2008 01:48 AM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
triode pentodes whitelabrat Tubes / Valves 7 17th October 2007 07:46 AM
Page generated in 0.07900 seconds (72.08% PHP - 27.92% MySQL) with 11 queries
