rectifier limiting resistors capacitor input - Page 2 - diyAudio
Old 2nd September 2009, 03:37 AM   #11
Originally Posted by tmhajw View Post
Hi There
Do people routinely use limiting resistors on the rectifier anodes for their capacitor input power supplies?! They seem to be occasionally mentioned as a good idea but I never see them on any schematics!
Thomas
Hi Thomas ,
Some time ago , I wrote a post about this subject , and how you can do
to calculate those limiting resistors . Perhaps it helps you .
In the rectifier tubes datasheets , you will find a parameter called " minimum
impedance per plate " .
When you know it ,there is a very simple ( but with good results ) formula to calculate the impedance :
Rt = Rs + Rp . N2 where :
Rt = Total impedance ( transformer natural impedance )
Rs = Secondary DC resistance , measured with a multimeter
and :
Rp . N2 = The influence of primary impedance over the secondary
( called reflected impedance )
where :
Rp = Primary DC resistance , measured with a multimeter
N = Transformer ratio ( Secondary Volts / Primary Volts )
Iíll give you an example :
Rs = 35 ohms
Rp = 6 ohms
Transformer ratio ( N ) = 300 VAC output / 117 VAC input = 2.56
Then Rt = 35 + 6 . ( 2.56 )2 = 74 ohms , that way , youíll need TWO 27 ohms resistors ( preferably , wirewound 5 watts resistors ) between each secondary tap and each plate of the 6BY5GA ( the tube that I had used as an example ), because 74 + 27 = 101 ohms > 100 ohms ( minimum impedance per plate )
If you use this formula with a split secondary ( center tap ) , you must to consider that :
( Rs ) will be the secondary DC resistance between one tap
and the center tap .
( N ) Transformer ratio will be the
HALF total secondary voltage / primary voltage
Did you understand ? You need to complete the transformer
natural impedance with resistors , to reach the minimum impedance value per plate .
Regards ,
Carlos
Old 2nd September 2009, 09:21 AM   #12
tmhajw is offline tmhajw  United Kingdom
Thanks Carlos thats extremely helpful.
I did actually measure Rs and Rp(to centre tap) when I put the amp together about 4 months ago but can't find the figures now of course, and to be honest, doubt if I used that formula at all- just remember R's being very low. Now I'm paranoid I'm being particularly stupid/worried for no reason and have added resistance where I don't need to... I shall haul the amp down tonight and remeasure...
Incidentally I was thinking of putting the thermistor just past the switch on the primary side- it would see mains (250vac) which seems to be within spec for many of them on the RS website (265vac max?)- just which one?!
Thanks again
Thomas
Old 2nd September 2009, 10:31 AM   #13
the Thermistor location varies with what you want the current limiting to do.
Fit the Thermistor in the primary side of the mains transformer to limit the start up current that the transformer draws at start up from zero core flux.
Fit the Thermistor in the secondary side to limit the charging pulses going through the rectifier to the smoothing capacitors.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd September 2009, 11:16 AM   #14
Ok so fitting one on the primary side won't particularly give the rectifier any protection against initial capacitor current surge. On the other hand, putting them on the rectifier anodes they see 450v they won't particularly like....
Enthusiasm has got the better of me, I've opened up the amp and measured Tx resistances...
Looking at Carlo's formula I've got these figures;
Rp 4.5r
n 400 (ct) /250
Rs 44.5r (per secondary winding to ct)
So I work out Rt to be 56r per anode
Interesingly I get a different answer if I put in figures pretending its not a centre tapped secondary...doh! I thought I was doing so well!
Now I look at the valve data sheets and anode impedence min is 75r or 85r for 450v for the 5u4g. So by rights I should take off my 100r resistors from the rectifier anodes and put in 22r 12w ones instead. Cool. Or running substantially cooler I hope.
Or can I just leave them off and be damned?!
Or, can I leave them off and just cheat and put in say a 100r or so after the rectifier before the capacitor input, so it's an rclclc p/s?!- would that still be 'good practice' for rectifier valve life?!
Comments (not rude ones) welcome!
Thomas
Old 2nd September 2009, 12:44 PM   #15
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
As was mentioned earlier, it is the rectifier peak current that is the problem, and ensuring the correct source resistance keeps it within the rectifier manufacturer's maximum limits. A thermistor won't help. Analyse the circuit in PSUDII and check that your peak current is tolerable according to the rectifier data sheet. If not, increase series resistance.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 2nd September 2009, 02:20 PM   #16
jackinnj's Avatar
Originally Posted by Boris_The_Blade View Post
Use PSUDII to find the actual RMS current through the resistors, instead of the average expected rectifier current (it will be much higher than you expect), which will explain the heat they can create. Rectifier data sheets spec'd the minimum plate winding resistances so it was easy for the users to avoid exceeding the maximum peak plate current for a given winding voltage, load, etc. I would avoid exceeding that at all, especially for new production tubes.
For SY's impasse preamp I noted that the power supply resistors were running much hotter than I expected. Total DC draw is about 38mA -- but the ripple measured on the scope was about 2V on the first 470R -- so the I^2 R was a lot higher for AC+DC. The first resistor in the chain ran between 95 and 100C, the second ran at 82C. This was in free air. In even in a ventilated case the temperature would probably rise a lot, perhaps to the failure level. FWIW, I am using fusible resistors these days...
Anyone measure the capacitance of a tube rectifier? -- I get around 10pF for a Sylvania 5U4GB.
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 2nd September 2009, 04:02 PM   #17
Gordy is offline Gordy  United Kingdom
My recommendations:
1. Add an inrush current limiter between the mains switch and transformer primary. I use a CL-190 (Mouser part number 527-CL190). When selecting the device check that A) the max current rating of the device is at least twice the nominal draw of your amp, and B) it's 'on' resistance at your amp's working current will not cause too much volt drop. (Note; you only need one, so ignore those who suggest adding them to both legs of the transformer primary). [ http://gb.mouser.com/Search/Refine.aspx?Keyword=cl-190 ]
2. Add limiting resistors in the anode legs of the rectifiers. Refer to the rectifier manufacturer's datasheet for suitable values. Calculate the values as described by Carlos / refference. Use high-dissipation resistors. Example; if you calculate that you need a 30 Ohm 2 Watt resistor then use 3 x 100 Ohm 2 Watt resistors in parallel for a total of 33 Ohms and 6 Watts. Space the resistors in free-air.
I'm not a tube expert, but doing it this way normally works.
Last edited by Gordy; 2nd September 2009 at 04:08 PM. Reason: "Because I felt like it" : )
Old 2nd September 2009, 05:20 PM   #18
EC8010's Avatar
Just about the same for a cold 12CL3 in a socket.
Old 3rd September 2009, 12:44 AM   #19
I've often seen the PSU11 mentioned and would be really interested to try it out- unfortunately it doesn't work at all well on my vintage imac...drat!
Thanks Gordy for your recommendations which make perfect sense. I will order some cl-190s in a minute. I'm also about to parallel up some 100r's, dropping series R to 33r. I'll see if I lose some of the heat....
Interestingly, the cl-190 thermistor initial resistance being 25r, would according to Carlos' formula, render series resistance sufficient without the use of anode resistors, as series resistance becomes around 120r per anode, well past the 75 or 85r minimum according to data sheets...(am I interepreting that right?!)- at least for the split second the thermistor doesn't conduct...
I think ideally I would like to eliminate the anode limiting resistors as they are only needed on start up and burn up power. With them gone perhaps I could reduce the input capacitor a little....
Thanks again
Thomas
Old 3rd September 2009, 01:43 AM   #20
jackinnj's Avatar
I never paid any mind to it, nor was it ever mentioned long those many decades ago, but we all had this type rectifier or some near-cousin in our Halliscratchers, Hammarlund, Heath and Eico stuff on the bands from 160 to 10M -- the RLC circuit formed by the rectifier tube, the leakage inductance of the trafo and the associated resistances all had some pernicious stuff going on and may have been associated with some of the fuzz one heard on the ham and SWL bands.
I put a 5U4GB warmed up on my HP3577 spectrum analyzer with a purely resistive load approximating what one would encounter in a ham receiver of the era -- and there is a point where the phase goes wonky just like a tuned circuit.
I dunno, probably doesn't account for a hill of beans...
Input capacitor Triox Solid State 92 5th August 2014 09:44 PM
resistors and capacitor which one have the best sound ??? prorms Solid State 28 4th March 2007 08:12 PM
resistors before the diode in a bridged rectifier: what does it do? jarthel Parts 2 5th September 2006 05:38 PM
Input Capacitor Shaz Chip Amps 3 20th September 2003 07:39 PM
Copyright ©1999-2017 diyAudio
