GU29 damaged
I just received a pair of GU29 for my ampli, and... give a look to the photo :eek:
It's chernobyl!!!
audioromy FU20 worth buy it ?
what about the sound of those FU29 amp/ chinese amp .
I'm really interested to buy one considering the price and specifications.... but it's difficult to find feedback about them.
The amp would be used with a lowther (full range) in a mauhorn iv enclosure.
Therefore thanks for your opinions !
Good sound. I have modified the power supply and the four caps with four soviet PETP. The original tubes are craps. Change them asap
I just got an Audioromy FU29 which was advertised by it's seller as being a SINGLE ENDED amp. I dug around in the thing and from my ohmmeter it sure looks like the 2 plates of the 829 are at opposite ends of the output transformer primary winding, with B+ fed to the tube via the center tap. That is a classic PUSH-PULL topology- NOT single ended!!!!!
Anybody here have any comment?
(It's a nice sounding amp, really, but it's advertised as SINGLE ENDED and it appears it is actually PUSH PULL!)
