| diyAudio Sponsor | ||
I know this probably isn't an easy one, two question to answer but....can anybody give me a fairly straight forward approach to calcuating the "load" resistance you use to run the calculations. For instance, I am buiding a fairly simple preamp using a single 5687 tube and I wanted to use this program to design a PSU....but I would't know the load resiator value to inpt into the program. I iagine if I am using 2 sides foe stereo then part of the value will be 1/2 the plate resistance at my voltage, but what about any other resistances in the circuit....do you just add them up? Th 5687 tube has a plate resistance of about 3000 at 250v as I recall, so two of these in parallel would be a resistance of 1500. WHAT ABOUT THE PLATE RESISTORS TOO? DO YOU JUST ADD THOSE IN TOO? these are 10k, so would it be the same...add 1/2 of this to the 1500 which equals 7500. Is there any thing else I am missing.
Thanks, Jeff |
#2 |
don't put a resistance in - put the total circuit current. Since your preamp will be running Class A the current is the same at all times, regardless of where its going.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
| PSUD2 help needed | soundbadger | Tubes / Valves | 5 | 2nd November 2007 04:27 PM |
| Psud2 Help | soundbadger | Tubes / Valves | 5 | 31st October 2007 10:19 PM |
| when using PSUD2, do you... | jarthel | Tubes / Valves | 13 | 15th August 2006 02:08 AM |
| RGN rectifiers in PSUD2... | Rocky | Tubes / Valves | 1 | 13th May 2006 12:57 PM |
| PSUD2 question | resident | Tubes / Valves | 8 | 6th October 2004 12:02 PM |
| Page generated in 0.06231 seconds (70.32% PHP - 29.68% MySQL) with 10 queries |
