| diyAudio Sponsor | ||
HI all
my amp http://www.audiodesignguide.com/my/n...ew300bxls.html with B+ 430v bias -87v I have only 53ma on all two Emissionlab 300bxls not near 100ma .... look at the opt ll1623 120ma ,the primary is wired as SE, the secondary have the pcb_B http://www.lundahl.se/pdfs/datash/1620_3_7.pdf http://www.lundahl.se/pdfs/datash/1620_pcb.pdf that mean 5.6k on 8ohm 3k on 4 ,my fullrange is 5.5ohm ,what is wrong?? Any expert on lundahl OTP?? Salas (thanks a lot!!) suggestion is that the trafo is config for 3k ie near 2k with my FR ,but for what I have understain this is possible only with PCB_C for secondary setting ..
#2 |
ideal\desired works point
#3 |
actual work point (by Salas
#4 | |
My 300Bxls uses Kron tubes in a setting like this. Only difference I use a 3K5 OT and they are running 130mA. Here's another without autobias, running 120mA.
jaap Last edited by disco; 31st August 2009 at 10:59 PM. |
#5 |
This is a tube/PS issue, not likely a transformer one.
http://www.ecpaudio.com |
#6 |
Sure and certain.
Use connection 'F' (8 ohm) and raise your supply voltage.
jaap |
#7 |
#8 |
today the main is a bit lower
main 225vac trafo 325Vac B+ 421Vdc V anode 408Vdc set the bias to -80v with Ia 70ma for now this suggestion point as I have low b+ can be good ? Last edited by nicoch58; 1st September 2009 at 07:52 PM. |
#9 | |
Make the secondary connection 'PCB-C' on your LL1623, as outlined in the document. Connecting a 8 ohm speaker presents a load of 3K to your 300Bxls tube and you are in the ballpark.
jaap |
| 300bxls vs mosfet :) | nicoch58 | Tubes / Valves | 7 | 13th August 2009 12:19 AM |
| Lundahl 4-30 Build | 83stang | Tubes / Valves | 5 | 25th October 2008 01:41 AM |
| Kron 300BXLS + Lundhal LL1623/120mA | grataku | Swap Meet | 4 | 7th June 2007 12:18 PM |
| Lundahl LL9206 problem | Pyre | Analogue Source | 2 | 28th May 2007 01:12 PM |
| AN SE OPTX KR 300BXLS Cerafine Cap Package Deal | mozfet | Swap Meet | 1 | 30th July 2003 12:47 PM |
| Page generated in 0.09458 seconds (76.95% PHP - 23.05% MySQL) with 11 queries |
