diyAudio Sponsor
Old 31st August 2009, 04:33 PM   #1
Default Srrp output question
In the circuite below what would the maxium ac output voltage using 150v b+
and a 10k load? Would I get about the same output swing if I took the output from the top of the top cathode resistor or the bottom of the cathode resistor.
Woody
Old 31st August 2009, 04:41 PM   #2
How do you post a picture? I was realy talking about a 6h30 triode with 170ohm cathode resistors and the bottom cathode with a bypass cap.
thanks,
Woody
Old 31st August 2009, 05:35 PM   #3
piero7 is offline piero7  Italy
piero7's Avatar
Upload the images on www.tinypic.com then copy the direct link image into the tag IMG (insert image button)
Old 31st August 2009, 09:02 PM   #4
Well I hope that worked.
Old 1st September 2009, 12:05 AM   #5
Geek's Avatar
Not familiar with the 6N30, but most SRPP, especially if high bias, can drive nails.
+150V isn't a lot for a totem pole, and each section will only have ~75V across them, but that looks perfect from the specs.
Anode current is rated 40mA, so 20mA through each totem would probably be a right balance for Gm, noise and tube life.
Depending on the cathode voltage needed, consider using LED's for bias... their impedance and noise is low and you can lose the cathode cap.
As for Vp-p out, that depends on what THD you want to take it at. Likely enough to cook a SS amp input stage before you even hit 0.5%
Cheers!
Old 1st September 2009, 12:41 AM   #6
vinylkid58's Avatar
I think that's a 6H30 in the schem. Gregg.
Jeff
Old 1st September 2009, 12:48 AM   #7
Geek's Avatar
Hi Jeff,
Cyrillic 6H30 == english 6N30, correct? TDSL seems to think so: http://tdsl.duncanamps.com/tubesearch2.php?TSD=6N30
Cheers!
Old 1st September 2009, 12:57 AM   #8
vinylkid58's Avatar
Yes that would be correct. Sorry, not trying to confuse the issue.
Jeff
Old 1st September 2009, 01:34 AM   #9
aardvarkash10's Avatar
[QUOTE=woody;1912443]In the circuite below what would the maxium ac output voltage using 150v b+
Maths here. Also check out Mu Followers for a variation and a hi-z lo-z option.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 1st September 2009, 01:40 AM   #10
Thanks for the feedback. But I would still like to know what the output
voltage would be at clipping.
Output Stage in MJ Question dsavitsk Tubes / Valves 3 30th December 2008 02:19 PM
Zen Output Question stefanobilliani Pass Labs 12 19th January 2008 01:18 AM
The output question of GC digi01 Chip Amps 1 29th January 2004 12:28 AM
OTL Output Cap Question Andrewbee Tubes / Valves 6 12th January 2004 07:45 AM
question on output devices! sardonx Solid State 3 2nd December 2003 10:22 PM
Page generated in 0.09282 seconds (87.78% PHP - 12.22% MySQL) with 10 queries
