| diyAudio Sponsor | ||
I recently grabbed on to a Monarch STA-100X AM-FM stereo receiver. It's a fairly simple, low end mid-60's metal box using a 6AQ8 and 2 X 6BQ5 single ended outputs. You know how a lot of Fleabay adds talk about their items being used in a non-smoking environment? Not this one... After a session with Mr. Simple Green and a brush and soft cloth, the thing will shed its nicotine haze and look fairly decent.The top needs to be wire brushed and repainted, as it's a bit scratched up.
Obvious other measures are a re-cap, as the electrolytics are older than a lot of the members of this forum. Anyway, does anyone have a lead as to where I could look for a manual? I want to cast a beady eye on the phono amp, the tone controls, and the power amp, as I can likely do a few things to improve them. An RH-84 type output amp comes to mind, for example. I suspect the same people made this as made my Lafayette amplifier, as the components and construction look similar. I'll probably set this one aside for awhile after I clean it up, as I have a host of projects ahead of it. However, I want to be thinking about what I can do for it. Schematics? |
#2 |
frugal-phile(tm)
Calrad . i believe was also by the same maker.
If it is SE it can't be all that hard to trace the circuit. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I'm not worried so much about the power amp as to the rest of the receiver. I haven't opened the bottom cover, but I'm expecting the usual point-to point hodgepodge. There is one PCB, I think devoted to the FM demux.
#4 |
Did you find a schematic or alignment data by chance?
I found one of these this summer at a yard sale as well WOT |
#5 |
There is an entity in Manila that purports to stock a soft copy of the manual, but I don't trust them enough to give them my CC number. If they took Paypal, I'd go for it.
#6 | |
Thanks WOT |
#7 |
Sams was the first place I looked - no joy so far.
#8 |
You can try Tom Bavis here too...
www.kta-hifi.net |
| Monarch SA-30 Schematic | n0plb | Tubes / Valves | 6 | 21st March 2010 01:29 PM |
| Monarch Series 8 Model 88 | Sh1mmy | Solid State | 0 | 30th July 2008 02:39 PM |
| Sony PS1 100x Service Manual | fmak | Digital Source | 0 | 9th February 2008 02:34 PM |
| Monarch 4" driver | woody | Swap Meet | 1 | 15th March 2005 11:28 PM |
| Yamaha NS-100x monitors (need info) | dentsinger | Multi-Way | 0 | 23rd January 2004 04:47 PM |
| Page generated in 0.09806 seconds (75.33% PHP - 24.67% MySQL) with 10 queries |
