diyAudio Sponsor
Old 19th August 2009, 12:40 AM   #1
kipman725's Avatar
Send a message via MSN to kipman725
Default 1:1 transformer replace with line filter
Hi for my HT supply I have a 1:1 transformer however it seems abit rubbish as even at 100VA it causes a very nasty transient in my other amplifier plugged into one of the rooms same sockets. It also seems to have a huge radiated field that's causing mains hum issues. This has me thinking, if the only reason for using 1:1 transformers is for protection against mains bourne transients and to prevent a device injecting noise onto the power line then can't I just replace the transformer with a line filter?
The transformer is enclosed in a steel case that is grounded to mains earth so I don't think there is any safety implications from this.
Old 19th August 2009, 01:10 AM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Looks like it has an interwinding short.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 19th August 2009, 01:41 AM   #3
leadbelly's Avatar
Default Re: 1:1 transformer replace with line filter
That's not even close to being the reason. They are there for galvanic isolation, an absolute must for safety.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Page generated in 0.07327 seconds (69.63% PHP - 30.37% MySQL) with 9 queries
