looking for a pinout on a ECLL800 audio tube if anyone has a link
please post thanks........ |
#3 |
thanks much
#4 |
diyAudio Moderator Emeritus
So, do you actually have one (or even a pair) of these valves? And what do you intend to do with them?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#5 | |
diyAudio Senior Member
You can actually make your own ECLL800s (or ELL800) as many a vendor has done for the passed 20 years...using a double pico7 socket, a pair of EL95s and one half of an ECC83...well you need to be a bit more inventive than that but that's what it amounts to. Cheers,
Frank |
#6 |
not making much of anything at the moment just wanted to see
the pinout on them. but i do have a working set just going to box em make somthing later
#7 |
no ecc83 here only ecc85
#8 |
Karma,
I hope you are going to save that ECC85 for an FM tuner, and not waste it on AF ![]() How did you get 2 ECLL800's? I've only seen 1 once in my life, and that was over 25 years ago! Cheers, |
#9 | |
Lorenz and TFK were the main manufacturers...hell, nowadays you can even find the resocketed ones anymore. Cheers,
Frank |
#10 |
buddy of mine found a box of tubs in this house he just got
. all tested good he's not into tubs so he gave them to me rare hmm
| Does anyone know the pinout of AES/EBU on XLR ? | Johnix | Digital Source | 1 | 15th July 2008 05:19 PM |
| Different pinout for the same BJT | alfaudio | Solid State | 3 | 29th June 2007 03:27 PM |
| Anybody knows pinout of RSN310R36? | valterdaw | Solid State | 4 | 12th July 2006 03:26 PM |
