| diyAudio Sponsor | ||
I want to draw up a list of valves which are pin compatible with the ECC88 / 6DJ8 type base configuration. I know of the ECC85, 6N1P, 6N2P, but what else? I'm not worried about functional compatibility, or different heater current requirements, I'm just looking for the same pin-configuration. |
#2 |
The 6DJ8 has the 9AJ pinout. Go get yourself a copy of Duncan's TDSL personal edition. Use the search tool to find all the tubes with the same pinout. There's too many to list here.
http://www.duncanamps.com/tdslpe/ |
#3 |
6FQ7
6922 - the Sovtec's aren't bad. I've never heard a 6DJ8 that sounds good to my ear and I've tried a lot of them Frank http://newmex.com/f10/ |
#4 | |
#5 |
6BQ7, 6BK7, various other similar numbers like 6BC8, 6BZ7, 6BS8. Also 6AQ8, 6DT8, 6CG7, 6GU7, etc.
#6 |
And let's not forget the best, IMHO, the 7308. and the best 7308, IMHO, the gold-pinned Amperex PQ or USN. I have a pair of USNs which are beyond incredible.
#7 |
7dj8 AKA PCC88 is pin compatible and functionally compatible, except for the heater voltage.
6n23p/6H23, 6n1, 6N11, CCa, CV5358 and Ecc189 / Pcc189 also come to mind, though the last two are remote cutoff tubes. Have fun!
Carlos Souza |
| Recommend me a warm, smooth sounding 6922, 6DJ8, ECC88 or equivalent | gaplessophile | Tubes / Valves | 36 | 3rd July 2009 07:24 AM |
| ECC88 Help | rhysh | Tubes / Valves | 2 | 1st December 2008 10:52 PM |
| 6DJ8/ECC88 mu-follower | SSassen | Tubes / Valves | 30 | 11th April 2007 08:19 PM |
| WTB: 6DJ8 / ECC88 / 6922 Tubes | mrdon | Swap Meet | 0 | 6th September 2005 09:58 PM |
| 6DJ8/ECC88 IEC 10M Master Series | Sidney | Tubes / Valves | 2 | 29th July 2002 05:43 PM |
| Page generated in 0.09186 seconds (73.07% PHP - 26.93% MySQL) with 10 queries |
