| diyAudio Sponsor | ||
Hello I have an arc V70 and it is imported from the USA the mains voltage is for 110 volts and over here we have 220 volts. I am operating this amp with an extra 220/110 volt transformer in between. Yesterday I had a look on the schematic for the arc classic 60 wich should be largely the same and I saw that the primary of the mains transformer has two 110 volt windings so a rewire for 220 volts should be possible now I hope that this is also possible for my V70 unfortunately there is no where a schematic to be found on the internet for the V70. I hope that there is someone to help me out on this one.
Thanks Rene. |
#2 |
The easiest thing to do is email AR and ask them. But according to the unofficial Audio Researsh Data Base website power requirements: "105-125VAC 60Hz (210-250VAC 50Hz) 500 watts at rated output, 700 watts maximum, 370 watts at idle." So it would appear that it is dual voltage rated. Why don't you open it up and look at the power transformer connections or wires. If it's dual voltage, the two primaries should be in parallel for 110V.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 | |
Thanks for the reply and that is a very good suggestion tomorrow I will have a look inside, if ther are 2 primaries. Thanks |
| Using mains transformer as output transformer | Elias | Tubes / Valves | 175 | 3rd November 2009 08:36 PM |
| Mains transformer help needed please | newtube | Tubes / Valves | 6 | 28th March 2009 05:12 PM |
| No mains transformer B+ ? | Salas | Tubes / Valves | 9 | 14th March 2007 11:04 AM |
| toroids for mains transformer | groov | Power Supplies | 8 | 6th September 2006 12:22 PM |
| Question on Mains Transformer | MlinarS | Tubes / Valves | 1 | 1st March 2005 11:57 AM |
| Page generated in 0.07604 seconds (67.17% PHP - 32.83% MySQL) with 10 queries |
