looking for fairly simple project for Eico 81 OPT's - Page 2 - diyAudio
Old 29th August 2009, 06:57 PM   #11
Shoog's Avatar
Originally Posted by jmillerdoc View Post
I just finished the Oddblocks project at www.Diyaudioprojects.com, which uses this type of CCS arrangement with a LM317 as a self inverting circuit. It sounds fantastic! I have never seen it using 2 CSS like here, I wonder what the purpose of x2 LM317's serve?
I think if I were to go this route again I woud use Bruce Heran's design for the EL84. Thanks though, again a very interesting design.
Jeff
By using two LM317's you fix the standing current in both valves which avoids core saturation in the OT. It never needs adjustment. The caps allow the differential nature of the output to be preserved.
Shoog
Old 30th August 2009, 05:27 AM   #12
DougL is offline DougL  United States
If I was looking for a project that used 8K:8 transformers,
the one I admire most is http://syclotron.com/?page_id=3, SY's RED LIGHT DISTRICT. Solid engineering, clear documentation. Looks like a straightforward build. no exotic parts.
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 30th August 2009, 07:33 AM   #13
Shoog's Avatar
Doug
Doesn't sound very special though.
Shoog
Will pay an experienced UK - based member to build a fairly simple circuit. iamweasel Swap Meet 1 14th March 2012 08:49 PM
This looks like a fairly impressive amp... Conrad Hoffman Solid State 10 8th November 2007 01:46 PM
Project using Eico ST 70 Iron? Vespasian Tubes / Valves 9 7th January 2007 11:38 PM
Fairly simple, relatively discrete switching regulator BWRX Power Supplies 7 11th September 2006 03:54 PM
Hopefully a fairly easy problem for you lot! Fraser Solid State 1 6th March 2004 05:26 PM
Copyright 1999-2017 diyAudio
