| diyAudio Sponsor | ||
Hello all,
I'm simulating a new hybrid amplifier, a pure class A hybrid driver (6N6P differential pair + mosfet) and a AB mosfet output stage. My ideaa is to build an "universal" hybrid class A driver and try different output configurations, from AB PP to pure SE (both solid state and vacuum based). The driver should be mounted on a separate PCB, while the power output stage could be mounted on the heatsink or on the amp chassis. Below the circuit I simulated for the driver and the complete amplifier (the first one) I indtend to try. Any comment? What do you think, is it a good idea? It simulate amazingly well, and it seems stable. The driver, supplied with a +155V and a -120V can output a 200Vpp signal with 0.017% THD. You also need the TL431 model to simulate my circuits, please find it HERE. Driver schematic: Complete amplifier schematic: Driver sim: Driver Amplifier sim: Amplifier let me know what you think. Ciao, Giovanni
In Nomine Libertatis Vincula Edificamus, In Nomine Veritatis Mendacia Efferimus. |
#2 |
One problem with tubes is the heat up time.
During this time the output will go to one rail and apply DC to your speaker. With my hybrid I simply bolt on an SRPP stage to the front of a standard class AB MOSFET amplifier.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
One more opamp...
#4 | |
As the SRPP tube stage has a gain of 13 I reduce the gain of the MOSFET amp by a factor of 13.
#5 | ||
At the end I think the only way to really know is to build one of this amp; I'm designing the driver PCB (the output stage will be wired point to point, for the first prototype), so we will see (or, better, listen). This post was just to see if there is any major issue with the idea, but it seems no one blamed the schematic. I'll let you know. Ciao, Giovanni
#6 |
You may want to check out the hybrid amplifier that appeared in the September 1997 issue of Elektuur. It used an ECC88 capacitor-coupled to a mosfet class AB push-pull stage, no global feedback.
If you PM me, I can get you a PDF version of that article. |
#7 | |
after you've done I would suggest you to try to replace R21/M7 by a BJT current mirror and compare results. |
| FYI: Hybrid MOSFET/Driver for Ultra-Fast Switching | RaiTulo | Class D | 0 | 17th July 2009 07:49 PM |
| amplifier for hybrid car? | star882 | Car Audio | 8 | 24th May 2009 04:50 AM |
| hybrid vfb-cfb headphone amp/driver | sparcnut | Headphone Systems | 6 | 14th September 2008 02:17 AM |
| Hybrid amplifier.. Please help.. | DoomPixie | Solid State | 96 | 2nd March 2006 02:54 PM |
| Horns + dynamic driver hybrid? | henkel | Planars & Exotics | 2 | 4th January 2006 01:55 AM |
| Page generated in 0.10805 seconds (79.83% PHP - 20.17% MySQL) with 10 queries |
