Crinkly tube getter Is this bad? - diyAudio
Old 27th August 2009, 06:56 PM   #1
Pyre is offline Pyre  Canada
Pyre's Avatar
Send a message via MSN to Pyre
Default Crinkly tube getter Is this bad?
I bought this tube and the getter is kinda flaking off. The tube tests good and the getter is still silver. Did something cause this or was it made that way? Will this cause the tube to fail or die early?
Old 27th August 2009, 07:29 PM   #2
HollowState's Avatar
I've seen this before. I'm not sure why this happens except to think that the inside of the glass may not have been as clean as it could have been. But as long as you keep any flakes at the bottom, you should be OK. I doubt it will shorten the life of the tube.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 27th August 2009, 07:33 PM   #3
Pyre's Avatar
Thanks, that is good to hear. Now I just have to figure out where to get another engraved base 50 for 20 bucks to go with it.
Old 27th August 2009, 08:13 PM   #4
Holy mackerel! A 50 for 20 bucks! I'm jealous. Better face Mecca and bow deeply for finding that one.
Old 28th August 2009, 04:55 AM   #5
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I have a vintage 45 that's like this. When it is not shorting, it works fine and tests strong. I'm weary about using it because there is getter all over the glass base of the internal support structure where all the wires come out.
In my old thread, someone mentioned something about dealers trying to re-fire getters to make gassy tubes test good and this can be the result. Not sure how true it is.
Old 28th August 2009, 01:20 PM   #6
SpreadSpectrum's Avatar
20 bucks? Seems kind of steep to me. I just picked up a globe shaped Cunningham CX350 at the local antique shop for $5.
Old 28th August 2009, 02:28 PM   #7
Pyre's Avatar
$5 bucks! nice. even in the 40's they were 3 times that.
Old 28th February 2014, 12:02 AM   #8
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Default More Getter flash flakingoff
I'm bumping this thread to see if there are any more answers.
I've purchased a few like the one shown in the attached photo.
They test OK and seem fine.
I doubt it is from anyone trying to refire the getter, as I've seen too many different types from different sources listed on ebay.
The only tubes I've seen it on are old ones with the silver getter. I've not seen examples of newer tubes that have the black getter flash.
What the heck does a getter do ? bereanbill Tubes / Valves 4 17th May 2009 07:51 PM
Detached getter? rknize Tubes / Valves 6 25th March 2009 05:32 AM
KT66 loosing its getter ixe13 Tubes / Valves 2 27th February 2008 01:33 AM
6D22S Getter Question Ardee Tubes / Valves 5 27th September 2006 09:35 AM
Plate color and getter Jeffy74 Tubes / Valves 9 23rd February 2004 11:14 PM
Copyright 1999-2017 diyAudio
