EF86 replacement
EF86 replacement
Old 26th August 2009, 08:16 AM   #1
Hojvaelde is offline Hojvaelde  Denmark
Default EF86 replacement
Hey
Now that the price of EF86 is towering , are there some who have tried to replace the EF86 with EF184 or EF95/6AK5 or 5654?
Yes, I know that the pin connections / sockets are different.
Benny
Old 26th August 2009, 08:28 AM   #2
Geek is offline Geek
Geek's Avatar
After testing, I have found the 6EJ7/EF184 to be very close in electrical performance and sonics.
My simple tests held true for pentode, triode and SRPP topologies.
Cheers!
Old 26th August 2009, 12:20 PM   #3
barretter is offline barretter  United Kingdom
I don't know how much Brimar 6BR7s cost these days but they were definitely designed as rivals to the Mullard EF86 (with a different pin-out, of course). There is also the 6BS7 which is the same but with the grid taken to a top-cap for even lower noise operation.
Old 26th August 2009, 03:47 PM   #4
alejo is offline alejo  Argentina
Hello, I build a version of Darling Amp (1626 SE Triode Amp) and I use EF184 triode straped as driver. The sound is very good, much more tha my RH807 (local feedbak).
Old 26th August 2009, 04:47 PM   #5
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
EF86 replacement
If I name 6J32P I'm afraid their prices will go up and tubes disappear from ePay...
Old 26th August 2009, 05:55 PM   #6
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
EF86 replacement
6AU6 has been suggested to me, haven't tried it yet (i have lots of EF86, but even more 6AU6)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th August 2009, 08:24 PM   #7
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
Originally Posted by Hojvaelde View Post
Hey
Benny
E80F and EF804 are good substitutes but may not be any less expensive, just
less popular... Different pinout on the EF804 at least
Old 27th August 2009, 06:27 AM   #8
mach1 is offline mach1  Australia
Banned
Get some loctal sockets and go EF40 (the EF86 predecessor with virtually identical specs) at a fraction of the price.
Old 27th August 2009, 07:28 AM   #9
Geek's Avatar
Ummmm... not loctal, it's that weird minature thing (B8A).
Cool thing is Shuguang is making sockets for them again, yay!
Cheers!
Old 27th August 2009, 07:35 AM   #10
B8a is called "rimlock" because of that little boss on the valve base which "locked" into a corresponding depression on the "rim" of the base. Not particularly weird in the 1940s.
EF86 replacementHide this!Advertise here!
EF86 trancy Tubes / Valves 51 16th February 2015 09:37 AM
EF80 vs EF86 newbadboy Tubes / Valves 6 16th April 2014 06:40 PM
EL84 + EF86 takashi Tubes / Valves 10 28th March 2008 02:30 PM
EF86 Gm dsavitsk Tubes / Valves 7 31st March 2007 07:59 PM
EF86 penthode specter73 Tubes / Valves 8 7th December 2005 05:38 PM
