Super Simple Valve Pre-amp Suggestions? - diyAudio
Old 26th August 2009, 08:55 AM   #1
Default Super Simple Valve Pre-amp Suggestions?
I've recently come into possession of an old Technics keyboard which outputs a very, very quiet signal, which I'd like to boost to get some use out of the thing.
I also found a ECC83 knocking about, so I'm wondering if I can put two and two together to make some kind of preamp for the keyboard?
However my electronics skills aren't up to much, I've only really dabbled with effects pedals and such so would creating a preamp be far too complicated?
I'm looking for the most idiotproof, basic schematic ideally.
Old 26th August 2009, 05:35 PM   #2
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
You might like to try the Real McTube.
http://www.dogstar.dantimax.dk/tubestuf/mchowit.htm
It has a bit of a cult following. Ok, it's a fuzz pedal really, but all the important parts are there, and it uses the same tube you have.
For keyboard obviously you'd want to tweak it for less gain and a clean sound, by reducing R4-R7, which is easy. The important stuff is that you have a working power supply to play with, and it uses two ordinary 12V transformers, so it's a great introduction and building-platform if you want to make the leap from pedals to real gear!
Old 27th August 2009, 04:57 AM   #3
CLS is offline CLS  Taiwan
Tube pres are mostly very simple in the signal circuits, or I should say simple enough. There're many single stage triode pre amps around. I don't know how one can make it even simpler.
However, inevitably any tube needs a certain "environment" to work properly. That'd be from fairly simple to ultra complex. Simple can be good, but too simple won't get you a nice result.
Tubes love clean power, lots of irons, voltage or current regulation... etc. These make things complex, but tubes always want them.
Old 27th August 2009, 05:24 AM   #4
aardvarkash10's Avatar
hmmmn - what is the signal level, and what is the preamp going to feed? A single, twin-triode tube actually gives a few topology options, but a bit more info is required before you could "recommend" any particular scheme...
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 29th August 2009, 04:04 PM   #5
This looks fantastic! Even found a site selling circuitboards for it so I won't have to go point to point, which I'm horrendously messy with. I guess it is mostly a case of tweaking the gain and reducing any noise. Haven't used transformers before though.
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 45 5th July 2013 11:50 PM
Simple Valve Preamplifier mangrovejack Tubes / Valves 15 7th April 2008 01:34 AM
The Super-Simple ChipAmp, Pt. II Spasticteapot Chip Amps 4 6th November 2006 12:43 AM
simple valve preamp mr l Tubes / Valves 2 21st October 2004 02:10 PM
Copyright 1999-2017 diyAudio
