stereo SE kt88 build ... abdellah diyaudioprojects design
Old 25th July 2016, 03:06 PM   #691
ta240 is offline ta240
Banned
I've got an issue with mine. It does great with most music but anything that has a lot of pretty continuous high notes, like pop where they just kind of fill in the background, I get a static sort of high pitch crackle sound with it. This morning it even did a completely separate crackle after the music.
On jazz or any other music that doesn't run a long stretch of higher notes it works flawlessly. The tubes have all been swapped out over time and it still does it.
Suggestions?
Old 18th January 2017, 12:22 PM   #692
bekim is offline bekim  Albania
Hi all,
Reviving this thread is a must :-) especially when help is required.
Question:
I can purchase OT Ra=5K I=200 mA and Power=30-40W for this design, and before i do that, will be any benefit if I connect two KT88 tubes in parallel (PSE) regarding output power?
Usually PSE OT for 2xKT88 Ra is 1.5kOhms. Any help is appreciated.
Thanks in advance.
Old 31st January 2018, 12:04 PM   #693
wdecho is offline wdecho  United States
Suggestions?
Sounds like a bad connection somewhere or bad solder joint.
Old 31st January 2018, 12:07 PM   #694
I just finished building a version of this amplifier with some bias changes to be able to use 6L6 tubes.
http://diyaudioprojects.com/Tubes/KT...-Amplifier.png
Great sounding amplifier. This amplifier is definitely a keeper of the more than 30 amplifier builds I have built.
Old 9th February 2018, 10:09 PM   #695
Banned
I should have posted an update, that is exactly what it was. A bad solder join on one of the coupling capacitors.
stereo SE kt88 build ... abdellah diyaudioprojects designHide this!Advertise here!
Stereo build- Mikael Abdellah's KT88 SE amp porkchop61 Tubes / Valves 124 10th March 2018 12:34 AM
Improvements for the Mikael Abdellah KT88??? 69CamaroSS396 Tubes / Valves 43 4th August 2017 07:49 PM
6CA7 Mikael Abdellah's KT88 SE amp? porkchop61 Tubes / Valves 24 20th February 2011 03:31 PM
new build - abdellah SE KT88 vince76 Tubes / Valves 19 31st July 2009 10:07 PM
Stereo Build - Mikaels KT88 matthew2456 Tubes / Valves 11 24th January 2007 04:56 PM
