diyAudio Sponsor
Old 20th October 2009, 02:23 PM   #51
revintage's Avatar
on your site the operating point
Hey Phillipe,
Nikolas site is great!
I´d absolutely replace the 6N1P with a 6DJ8/6N23 if we go from the measurements. But one have to redesign the circuit to suit them.
Brgds
Lars
Old 20th October 2009, 02:55 PM   #52
revintage's Avatar
If we go by Nicolas curves, a Rk of 470ohm(-75/+80V swing/5mA) would be far better than the 1k in the original.
Brgds
Lars
Old 20th October 2009, 02:57 PM   #53
Sorry for the confusion (and my poor english), I meant "the site you talk about.
Thanks for "redesign the circuit to suit them."
Philippe
Old 20th October 2009, 06:40 PM   #54
jmillerdoc's Avatar
The original design and schematics I found for this amp at diyaudioprojects.com has a line at the bottom of the page where the builder preferred a 6DJ8 Amprerex Bugle Boy tube. I presume it must work in this amp because of the authors comments.
Thanks,
Jeff
Old 24th October 2009, 09:39 PM   #55
88man is offline 88man  United States
Do you have to use polarized electrolytics for bypass caps for the 100uF/25V and 220uF/63V values?...
Can you use non-polar MKP capacitor instead, like Mundorf MKP Supreme, Auricaps, or Clarity PX, or Solen Fast Caps without degradation?...
I can't find values for Black Gate caps since they've been long out of production. Any advice on top tier alternatives?...
Old 25th October 2009, 01:23 AM   #56
jmillerdoc's Avatar
I like Elna Cerafine, large selection at Partsconnexion. Also Nichicon KZ Muse does well too. Check out the above vendor, lots of nice stuff there.
Old 25th October 2009, 01:27 AM   #57
jmillerdoc's Avatar
Default Chassis ready to go
Here is a sloppy pic from an Iphone of my chassis, ready to go. I will try to post some better pics later when I have access to my camera. The wood from bottom to top is Cedar, Canary, Rosewood, Canary, Madera, and Oak. You can see my hugh, ugly, 200mA 10H Westinghouse choke mounted up underneath. I just got all of the parts in a couple of days ago, should have her together in a week or so.
Jeff
Old 25th October 2009, 07:14 AM   #58
jmillerdoc's Avatar
So if I wanted to use my 6DJ8, what changes would you reccommend in the circuit?
Old 25th October 2009, 09:07 AM   #59
revintage's Avatar
Just adjust Rk to get between 120 and 150V Ua. Probably in the ballpark of 500ohms.
Brgds
Lars
Old 25th October 2009, 05:17 PM   #60
Thanks Jeff for suggesting the Elna-Cerafine and the Nichicon KZ Muse caps. I'll try Partsconnexion. I've heard the Elna-Cerafines have 98% of the sonic attribuites of the Black Gates. I wonder how they measured that, but it seems good enough!... Oh, hey I see you've put the cart before the horse, but the enclosure looks distinctive.
Stereo build- Mikael Abdellah's KT88 SE amp porkchop61 Tubes / Valves 119 3rd April 2011 06:41 AM
6CA7 Mikael Abdellah's KT88 SE amp? porkchop61 Tubes / Valves 24 20th February 2011 04:31 PM
Improvements for the Mikael Abdellah KT88??? 69CamaroSS396 Tubes / Valves 42 16th December 2009 02:58 AM
new build - abdellah SE KT88 vince76 Tubes / Valves 19 31st July 2009 11:07 PM
Stereo Build - Mikaels KT88 matthew2456 Tubes / Valves 11 24th January 2007 05:56 PM
Page generated in 0.11501 seconds (77.57% PHP - 22.43% MySQL) with 11 queries
