| diyAudio Sponsor | ||
#511 |
I have a couple spare parts at home. can they be used for this amp? 5v4g, 3.5k opt trans?
#512 |
thanks everybody for all the answers and good advice
made some changes yesterday replaced the el34,s with sovtek kt88 i like the sound ,it handels my speakers with more ease replaced the 5u4gb with a sovtek 5ar4 the b + went up with 43 volts to 415 the whole amp seems to be more powerfull ,better bass response i think i leave it a few weeks like this ,to simply enjoy the music instead of lissening for a better bass or crispyer high etc etc i am queit satifyed with the sound at the moment and the weather is getting better, so my old vintage vw baywindow bus [1976] is asking for maintaince [a lot of it] ![]() greetings from a sunny amsterdam ko |
#513 | |
#514 |
I have done some more experiments using CCS. The conclusion is that the original design is very optimized.
With a CCS and led I can bring the distortion of the driver from 1.3 % to 3 % at 10V swing, but the overall distortion of the amp increases slightly, compared to 47K resistor. Probably there is the distortion cancellation effect between the first and second stage that plays a role, as someone adviced. To reduce overall distortion the only way I found is to decrease the cathode resistor of the KT88. From my calculations you can go down to 330-350 ohm and still be on the safe side. like this you will drain around 90 mA and still be inside the max plate dissipation. I have to do some listening, tired of 1 KHz tone :-) Any comment ? Davide |
#515 |
Sorry, read " bring the distortion of the driver from 1.3 % to 0.3 % at 10V swing"
D. |
#516 |
Hi all,
I am in process of building this amp but I got stuck in OPT. Would it be sufficient to use GXPP15-8-5K from Edcor, considering it's a 15w transformer or I must go with CXSE25-8-5K ? Thanks, alex |
#517 |
i built mine with the CXSE25-8-5k, i have use the gxp15 and theyre good for the price but for this built "KT88" i i prefered the bigger iron looks better too.
#518 |
Thanks Tim.
Awesome amplifier you built here. Just waiting for an answer, I browse 5u4-gb datasheet. What they say here is that you MUST NOT connect the tube directly to the transformer but to use a resistor so that the transformer resistive value +the additional resistor should be in the range of 170Ohms. I didn't buy the transformer yet as I was looking at Edcor XPWR033 or XPWR002 , tube 5u4-GB 33uF - 10H (Hammond 193J) 220uF. Could you please share your working schematic? Thanks, alex |
#519 | |
I am building a SE with 6L6GC-STR in the finals (RH807 / Kegger used as base). What I am doing is putting a variable resistor in the cathodes of the output tubes. There are some very nice and small 12.5 Watt, 500 Ohm rheostat from Ohmite on eBay at this moment at a very reasonable price. After I got the first pair in I ordered this week a second pair just to have them for some future project. At this moment there are over 10 available and shipping to New Zealand is USD 6.00. ( OHMITE 500 OHM 12.5 WATT RHEOSTAT - eBay (item 400092245495 end time May-15-10 18:07:40 PDT) ) This allows me to easily adjust the anode current for the "sweet spot". AM |
#520 | |
depending on voltage different transformer resistance values are required but also be carefull of not using a capacitor larger than specified. These values are required to prevent too large peak currents through the recitifier tube. Model the PSU in PSUD II (duncanamps.com), it takes only a short time to get familiar with the software and prevents a lot of troubles later on. AM |
| Stereo build- Mikael Abdellah's KT88 SE amp | porkchop61 | Tubes / Valves | 119 | 3rd April 2011 06:41 AM |
| 6CA7 Mikael Abdellah's KT88 SE amp? | porkchop61 | Tubes / Valves | 24 | 20th February 2011 04:31 PM |
| Improvements for the Mikael Abdellah KT88??? | 69CamaroSS396 | Tubes / Valves | 42 | 16th December 2009 02:58 AM |
| new build - abdellah SE KT88 | vince76 | Tubes / Valves | 19 | 31st July 2009 11:07 PM |
| Stereo Build - Mikaels KT88 | matthew2456 | Tubes / Valves | 11 | 24th January 2007 05:56 PM |
| Page generated in 0.14568 seconds (79.47% PHP - 20.53% MySQL) with 11 queries |
