Lost a channel in my TSE - diyAudio
Old 24th August 2009, 02:52 AM   #1
oldmanStrat's Avatar
Default Lost a channel in my TSE
So I sat down tonight for some easy listening, powered on my TSE and there was an immediate pop on one of the speakers... Oh boy... then the other one powered up as normal.
Swapped the inputs, no joy. Hooked up my SSE and both speakers play. Haven't done anything else yet, but I will swap input tubes and the 300b's tomorrow early in the eve. All the heaters are glowing...
Any words of wisdom on what to look for (besides the obvious burnt resistor) in the signal path?
I really hope it's not a 300b... too pricey for me to replace right now.
Oh and what is with the head shot smiley? Pretty nasty for a smiley face...
For security reasons my name is changed daily...
Old 25th August 2009, 01:21 AM   #2
Ok, that was strange. Swapped the 300b's, powered it up, and it was like there wasn't ever a problem...
Old 25th August 2009, 02:41 AM   #3
It sounds like there may be a loose contact somewhere. Just a guess.
Old 25th August 2009, 04:12 PM   #4
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Next time it happens take a look at the 300B filaments. If one is out, try wiggling it. Then check the solder on the sockets. If they look good, swap the tube again and see if the problem follows the tube. If it does, you can try to reflow the solder in the pins or if your warranty has not expired, get it replaced.
If the problem is not the tubes, use a plastic rod or something non-conductive and lightly prod at the components on the board to see if you can find the culprit. May be a cold solder joint or a short somewhere.
Old 26th August 2009, 01:13 AM   #5
Hmm the only problem with that Russ is that the top is on, and to remove it to get to the PCB I have to take out the 300b's. Last time that is what fixed the problem... but good suggestions if it happens again.
Lost bias on Marantz 1060 right channel DragonMaster Solid State 20 11th November 2009 03:23 PM
Yamaha cr-620 bass is lost in one channel YAKI Solid State 8 13th December 2008 06:26 PM
oh oh i lost a channel ginsner Solid State 5 18th August 2006 04:53 PM
4-pins pot - I'm lost... e-manu38 Parts 3 1st December 2004 09:42 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
