#31 |
The attached schematic is the original McIntosh Amplifier's
published in 1949. It uses Bi-Filer winding for P and K windings. Therefore 100% feed back is applied to the Cathode. Since the Cathode should be the referenced potential, resulting 100% feed back is applied to both G1 and G2. The attached schematic uses 100% positive feed back to G2 to cancel G2 negative feed back. Therefore only 100% feed back to G1 is remained as the beam connected 6L6. E-Linear uses 50% tapped feed back to both G1 and G2 if UL tap is 50%. Last edited by ja2dhc; 29th August 2009 at 02:21 AM. |
#32 | |
E-Linear tapping is up to the output TX winder. I am using multi-tap designs so the amout of FB can be adjusted. 20-30% is adequate, but with OPT designs running 40% U-L taps it is not a large handicap. The larger tap percentage requires more voltage headroom from the amplifier stage, and would work best with AB designs instead of the B+ limited Class A designs...unless we go to large power finals that can take Class A dissipation at higher voltage... ![]() cheers, Douglas
the Tnuctipun will return |
#33 | |
There's a Krohn Hite unity-coupled amp out there with a bootstrapped pentode driver good for ~0.0015% THD at 35 watts, using 80 dB total feedback.
#34 | |
cheers, Douglas
#35 | |
feed back to McIntosh without special winding transformer, but needs UL tap. As Bandersnatch says, value of feed back can be adjusted by the percentage of UL tap. In my case, I added two pieces of 39Kohm to the plate of the driver, it reduces G1 feed back to the half, resulting, the driver's operating condition could be relaxed. Please refer to my schematic as below. http://ja1cty.servehttp.com/E-LINEAR/E-Linear-amp.png '73 de JA1CTY & JA2DHC/1 Kazuo Ohashi |
| Is it an advantage to use this one instead of 2SC5200 or 2SA1943? | destroyer X | Solid State | 8 | 11th December 2009 04:57 PM |
| Advantage of a FET-BJT CCS vs BJT only | Bitrex | Tubes / Valves | 2 | 10th June 2009 03:01 AM |
| Any advantage of increase VDD to +6V for tda1541a? | Sunsun22 | Digital Source | 4 | 30th December 2008 03:40 PM |
| Another advantage of IB | mashaffer | Subwoofers | 2 | 15th September 2007 04:57 PM |
| advantage preamp | seahag | Chip Amps | 9 | 4th October 2005 01:23 AM |
