| diyAudio Sponsor | ||
I wanna build the C3M linestage in triode mode.
Does anyone have the good scheme.... Please..... Thanks Regards, Hendra |
#2 |
why not just use a triode ?
#3 | |
Because it is a really linear tube as a triode, and because there are few, if any, triodes that have similar specs.
http://www.ecpaudio.com |
#4 |
i wanna build this c3m with anode follower (RC) topology.
i will use this preamp with 6sn7-300b single ended (JE lab design). I've heard that this tube sound great as triode, so i wanna try to build one. My plan is B+ 300V Please help thanks Regards, hendra |
#5 |
i will use this preamp with 6sn7-300b single ended (JE lab design). I've heard that this tube sound great as triode, so i wanna try to build one. My plan is: B+ 300V Vp 150V Rp 22 K Ip 7 mA Rk 0.5 K Bias -6 V How about that.... Please help thanks Regards, hendra |
#6 |
Do you need a pre with the JElabs?
Swapping the 6sn7 cascade with a c3m as pentode could be worthwile though... Just my blabla Simon |
#7 |
thanks for your comment
i think the je labs gain is not high enough... |
#8 | |
See here for distortion comparison between c3m pentode and 6sn7 cascade: http://www.pmillett.com/pentodes.htm Should you be interested, schematics for c3m + 300b amps can be found here: http://www.fortunecity.com/rivendell...cy/Legacy.html http://www.diyparadiso.com/sedesign1.htm Edit: Millett's page does not feature the c3m, but the measurements of other high-gm pentodes should give you a basic idea... Simon Last edited by Klimon; 21st August 2009 at 11:43 AM. Reason: Passing time |
#9 |
I think I'd swap the tubes around. Use the C3m to drive the 300B and use the 6sn7 somewhere else.
#10 |
Use the C3m in triode with a CCS to drive the 300B and you won't be disappointed. In my opinion the 6SN7 is a gutless driver.
| C3m linestage | bequerel | Tubes / Valves | 32 | 14th April 2009 06:03 AM |
| 48V B+ linestage | hirafu_boarder | Tubes / Valves | 24 | 11th May 2008 05:57 PM |
| My 6S19P Linestage | sorenj07 | Tubes / Valves | 4 | 12th April 2008 06:21 PM |
| An almost DIY 6DJ8 Linestage | JesseG | Tubes / Valves | 37 | 17th November 2007 11:43 PM |
| Another linestage...... | kianbach | Tubes / Valves | 11 | 28th June 2005 05:34 PM |
| Page generated in 0.11520 seconds (86.06% PHP - 13.94% MySQL) with 10 queries |
