Tube rollers - what tubes for my RH84?
Old 20th August 2009, 09:40 AM   #1
Brisso57 is offline Brisso57  Australia
Brisso57's Avatar
Default Tube rollers - what tubes for my RH84?
I'm about to commence building my first tube amp, an RH84.
The tube complement is
1 off 5U4 rectifier
1 off ECC81
2 off EL84
I'm not interested in hearing about unobtainium, but what have RH84 builders out there found to be sweet tubes, or sweet combo's?
* Yes, I know sound quality depends on the iron and also on the passives, but I want to limit this discussion to experience of tubes in this amp.
What should I buy?
cheers
Doug
Old 20th August 2009, 09:48 AM   #2
Klimon is offline Klimon  Belgium
Do try the philips/mullard manufactured el84's. These can be branded Valvo/dario/miniwatt... but sound equally fantastic.
Simon
Old 21st August 2009, 06:26 AM   #3
Brisso57's Avatar
Thanks Simon.
Anyone else with a recommendation?
Doug
Old 21st August 2009, 07:27 AM   #4
NICKEL is offline NICKEL  New Zealand
I've tried a few, the cheap Russian NOS are pretty good. Certainly not night and day compared to Teles or Amprex. To be honest - I've lost interest in tube rolling - its cost heaps, with no corresponding payback compared to say drivers and amps.
Old 22nd August 2009, 02:24 PM   #5
disco is offline disco  Netherlands
disco's Avatar
Use quality capacitors for C1 (10uF-350V), it pays off.
For the power supply use a beafy transformer (250mA HT), this is my setup.
Must admit that this amp sounds much bigger than the 5+5W it puts out
jaap
Old 22nd August 2009, 02:37 PM   #6
kevinkr's Avatar
The Russian 6P14P-EV or ER is a good sounding 6BQ5 equivalent and quite rugged - readily available on eBay for little money. It is one of the nicer sounding tubes I have tried in some hi-fi SE amps. Compared them to Telefunken 6BQ5 and GE 7189A. IMO it was better sounding than the GE, and I thought was very comparable to the Teles.
Give 'em a shot..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 22nd August 2009, 02:46 PM   #7
disco's Avatar
The ECC81 I liked best was NOS Mullard. Also old production Philips and Brimar are excellent. When buying used tubes be sure they measure up to spec because there's a lot of worn out junk for sale. Don't pay more than 15 - 20 euro for a NOS ECC81.
jaap
Old 23rd August 2009, 07:49 AM   #8
Brisso57's Avatar
Thanks Guys. Good stuff!
Disco, can you translate "lichtnet" for me pls?
Doug
Old 23rd August 2009, 08:57 AM   #9
disco's Avatar
Don't you have a lichtnet downunder?
Man, you're missing something
Try mains instead
jaap
Old 23rd August 2009, 04:16 PM   #10
kevinkr's Avatar
Give 'em a shot..
I should have noted while not exactly identical to the RH84 the amplifier in question was based on the RH84 and is generally similar. (Same principal of operation, just a few values tweaked - the amp was not one of mine.)
Tube rollers - what tubes for my RH84?Hide this!Advertise here!
Building RH84 SE tube amp. Forsman Tubes / Valves 160 29th September 2014 12:33 AM
Rh84 Ptx tim614 Tubes / Valves 17 10th August 2010 01:28 AM
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
who reconditions rubber rollers?!?!?! hi_im_sean Analogue Source 4 25th April 2005 05:37 PM
