What is meant when tubes are sold as "matched"?
Old 20th August 2009, 08:46 AM   #1
Brisso57 is offline Brisso57  Australia
Brisso57's Avatar
Default What is meant when tubes are sold as "matched"?
Newbie here.
I'm gearing up to build my first tube amp - an RH84.
I see on fleaBay and elsewhere tubes (both new and used) advertised as matched pairs or matched quads ...
What is meant by this term?
What properties are measured to enable tubes to be rated as matched?
What % tolerance is generally permitted within matched sets?
Doug
Old 20th August 2009, 10:18 AM   #2
On Hiatus
SY's Avatar
It means whatever the seller decides it means. There are no standards and about a million ways to do it that all give different results. Caveat emptor!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 20th August 2009, 10:39 AM   #3
kavermei is offline kavermei  Belgium
kavermei's Avatar
Send a message via MSN to kavermei
Ideally it SHOULD mean that the tubes draw equal plate current and have equal transconductance/mu/rp at the plate voltage and grid voltage at which you intend to use them.
But I think 99% of the sellers on eBay will not be able to back this up when asked. Most will just have sticked the tubes in a tube tester and seen that the needle points more or less in the same region...
Old 20th August 2009, 10:44 AM   #4
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Usually: nothing.
Old 20th August 2009, 01:28 PM   #5
richwalters is offline richwalters
richwalters's Avatar
Yup, sloppy heater wiring will put physics charateristics haywire. The idea of "matched" isn't bad because someone has put the stuff on test or soak bed, so the chances of one receiving a duff tube have been reduced but not diminished. A good vendor will colour spot the tube and if goes foul will replace with a sim.
richy
What is meant when tubes are sold as "matched"?Hide this!Advertise here!
Question about the properties of "matched" tubes skittletata Tubes / Valves 8 18th March 2008 03:37 PM
do matched pair (or maybe a quad) output tubes "aged" at the same rate? jarthel Tubes / Valves 3 9th June 2007 02:05 AM
What is meant by "BBC rise"? Javachip Multi-Way 100 31st July 2006 07:32 PM
