diyAudio Sponsor
Old 20th August 2009, 05:52 PM   #21
Brit01 is offline Brit01  United Kingdom
I use a light bulb too, but I've never seen it light up.
last night I discharged 2 x 400V 680uF caps. Lit up the whole street for 3 seconds and a few sparks flew when the leads touched the cap!!!
Old 20th August 2009, 09:12 PM   #22
ChrisA is offline ChrisA  United States
Originally Posted by boywonder View Post
Some amps have these drain resistors built-in but many do not, so it's a great habit to check the volts on the power supply caps (with one hand) before diving in to work.
If you ever find an amp that does not have these. Stop. Go find a 100K resistor and solder it across the power supply. If you do a little analysis you may find you can use a lower value resistor but the high value one can almost always be used. There is no reason not to have a permanently installed bleeder resistor.
I'd say the same about two prong power cords. If you see one, stop. get the three prong grounded cable wire it in before doing any other work on the amp.
I can go on... Hammon built amps with no fuses on the AC. That was nuts even in the day. If you see one of these amps, fix it.
Old 20th August 2009, 10:32 PM   #23
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by SY View Post
Dumb question- why are standard IFs what they are? For example, most AM broadcast band radios have it at 455kHz, FM at 10.7 MHz. Why not 450kHz and 11 MHz?
There were 456 KHz snandard here, and 465 KHz standard in Europe. Germans used exactly 1 MHz in their Kehln receiver. American BC-348 used 915 KHz. Russian military used 500 KHz. And so on. I don't know why.
Old 21st August 2009, 02:04 PM   #24
Hi-Q is offline Hi-Q  England
Hi-Q's Avatar
You should check out the tube arrowed in the picture, it looks a little soft to my me, maybe lost all its vacuum. Whatever you do avoid touching the chassis while taking measurements. The wise words about high voltage and safety already given by other Forum members should be well ingested, like myself, many have learnt the hard way and we just want you to take care.
Old 23rd August 2009, 09:10 AM   #25
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Originally Posted by tubelab.com View Post
How about a tube head who is a radio ham and has worked as a radio design engineer for the past 36 years?
Thanks for a more detailed explanation from the horse's mouth.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
simple questions, can't find the answers pjaneiro Multi-Way 14 8th August 2007 10:28 AM
#halojoy - Answers DIY audio questions In Person halojoy Everything Else 1 10th August 2003 01:52 PM
Page generated in 0.08900 seconds (70.47% PHP - 29.53% MySQL) with 11 queries
