| diyAudio Sponsor | ||
I recently bought a mono tube amp from a member here on the forum that turned out to be a excellent deal, in excellent condition, thanks again cscmc1!
(pics can be found here) FS: Boulevard el84 amp Purpose: I would like to turn this amp into a mono guitar amplifier, and retrofit it to an older marshall head case that I have. Boulevard 5T-17 Specs: 17 Watts 1 x EZ81 Rectifier Tube 2 x 12AX7 pre amp 2 x EL84 output tubes 4,8, and 16 ohm outputs work (screw terminal type) The amp had been modified and simplified, but the seller wasnt exactly sure what had been done. I also ordered the original schematic, and have found the following changes: Volume pot was removed Tone / Bass / Trebel / Selector switch removed All wiring except the aux RCA style input has been removed Is it possible to: I would like to add a master volume control pot, and if possible a bass and trebel control, and a tone knob. I am relatively new to the point to point wiring, and tube amplifiers, but I am very handy with a DMM and a soldering iron. I do have the orignal schematic available, I am going to upload it this evening if it would be helpful. Questions: How do I go about adding a master volume knob? How do I add a bass and or trebel control? Where can I find a schematic for a basic tone stack ? (if thats using the correct lingo?) Is it possible to add a seperate gain control to add a bit of distortion without cranking the volume? Do I need to include a stanby circuit like alot of larger wattage amps have? Can I repaint the power tranformer with regular spray paint? Its a bit rusty As always please point me in the wrong direction if I have overlooked something simple. Please take it easy as I am new to the hobby.
#2 |
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#3 |
I have scoured that particular forum and been soaking up information, I found that site a few weeks ago. I was just looking for a more personalized answer(s) from forum members. Its a bit easier to read one response from a member than it is to search multiple threads for hours.
I will check that site over again, thanks for the recommendation. Can anyone answer any specifics for me here? Thanks again |
#4 |
I have also found this particular site useful, just a reference link for anyone interested
http://www.netads.com/~meo/Guitar/Amps/PA2Guitar/ But I havent found answers to how to add the tone stack, and whhat I can use to repaint the transformer. |
#5 |
Ok I've found a basic marshall tone stack called "18 watt" found here
http://amps.zugster.net/articles/tone-stacks#18Watt So I am going to incorporate that according to the information in the link provided above about converting PA amps to guitar amps. I think that should cover some of my questions. I am open to any feedback or ideas for this project, and I will be uploading pictures soon.
| Hickok TV-7/U restoration advice needed. | bembel | Tubes / Valves | 2 | 21st January 2007 08:30 PM |
| Bogen CHB-10A Conversion, need help and advice | Turbo7MN | Tubes / Valves | 14 | 22nd August 2006 02:29 PM |
| El84 2-Channel Mono Blocks | alexmoose | Tubes / Valves | 1 | 8th August 2006 07:39 AM |
| Mono block restoration | soundfan | Tubes / Valves | 6 | 29th January 2005 12:27 PM |
| Advice on PS conversion | KODO | Solid State | 1 | 26th April 2003 02:44 AM |
| Page generated in 0.08592 seconds (74.59% PHP - 25.41% MySQL) with 10 queries |
