diyAudio Sponsor
Old 12th August 2009, 12:16 AM   #1
coldcathode's Avatar
Default Looking for curves for obscure tube
Been real busy working around the house until recently. I was sorting some of my collection and started with globe and st shaped tubes. I came across what appear to be NOS Tung-Sol 485' (4 of them). The only data I can find is make plate voltage of 180 and Mu of 12.5 or so. I am wondering if anyone has in their collection of data some curves? It appears this was a very little used tube. I am always up for a challenge and I was thinking a nice line stage using these might be nice.
Anyone got any further info on these?
Old 12th August 2009, 12:22 AM   #2
Tom Bavis's Avatar
It's a Sparton number, don't know if anybody else used 'em. You could probably use the curves for 56, 76, 6P5 or 27 and be close enough.
Old 12th August 2009, 01:41 AM   #3
tubelab.com's Avatar
I can't find any info on the 485, but I can offer this. I found an old Sparton radio chassis in the dirt at a flea market. I got it for $10. It had a bunch of globe tubes in it and I don't remember all of the numbers. The output tubes were marked National Union NX-483. They had a guarantee sticker from 1929! The NX483 turns out to be the same as a 183 which is an output triode that works like a 45 with a 5 volt filament. They sound really nice in a Tubelab SE.
It is possible that the 485 could be an NX-485 or could be similar to a 185. A quick Google search didn't turn up anything, but maybe some of the old radio sites may have some info.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 12th August 2009, 01:19 PM   #4
Thanks guys! I guess what I will do is try a simple gain stage and cathode follower and listen??
I come across a lot of interesting tubes using the "flea market" method. I have also found that showing interest as "something I know nothing about but would like to play with" gets the price much lower than giving away that I know about tubes. LOL
Quick question that I know both of you can answer,
What load resistance should I use if I know the Plate resistance from the little data I have?
Computer program for tube curves and Spice models Jim Tonne Tubes / Valves 9 21st November 2010 10:10 AM
Tube curves tracer Yvesm Tubes / Valves 8 5th December 2007 06:41 PM
Do tube curves tell most of the story? bigwill Tubes / Valves 8 18th November 2007 05:54 PM
Tube curves merkur Tubes / Valves 4 13th September 2007 06:17 PM
Obscure radio tube AmpKiller66 Tubes / Valves 2 8th March 2007 09:26 PM
Page generated in 0.07557 seconds (67.71% PHP - 32.29% MySQL) with 10 queries
