Triad N-68X Tranny for ^SN7 Aikido?
Old 11th August 2009, 01:58 AM   #1
john65b is offline john65b  United States
john65b's Avatar
Default Triad N-68X Tranny for ^SN7 Aikido?
Hello all,
I have used the 220VAC -> 110VAC Triad N-68X transformer (wired in reverse) for a preamp power supply before on a 12B4 pre, and wonder if it can be used for the 6SN7/6SN7 Aikido.
The tranny should be able to do a target of 125ma easily enough. Spec sheet is attached...
I have to run it in PSU designer, but should be around a B+ of 270V with a SS Rectifier and CRCRC filter...
I have a separate tranny for the filaments.
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 11th August 2009, 02:12 AM   #2
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
It should work fine.
Old 11th August 2009, 02:25 AM   #3
john65b's Avatar
Good deal...thought to ask first...
Old 9th March 2012, 02:44 AM   #4
john29302 is offline john29302  United States
john29302's Avatar
Default triad nx66
This is driving me nuts. i have a aikido preamp powered by a nx66 transformer. hooked up backwards to get 230 volts. it has a loud mechanical hum. even with no load. should i order another or what. this transformer also has a shield in the primary side that is often mistook for a center tap, it is not. so remember that what i am calling the primary is what i use as the secondary. so does anyone else have a mechanical hum? its loud enuff to hear and gets very annoying.
Old 9th March 2012, 02:51 AM   #5
john29302's Avatar
oops its actually a n68x same as above and i wired it correctly. its that white wire that is the shield and it is on the secondary side and i use it as my primary side. thats what i meant anyway loud mechanical hum. do not know if its just a bad one or to order another one.
Old 9th March 2012, 03:16 AM   #6
john65b's Avatar
You tied red/black to yel/black and measured from Black to Green/black with 110v mains on the reds?
White does not get connected at all. Is the tranny hot?
Old 9th March 2012, 04:06 AM   #7
audiohead is offline audiohead  United States
I use a signal transformer A-41-43-230 with the same annoying buzz issue.
Mine is a Aikido LSA/HPA board.
I have the triad toroid VPT230-220 on order from Mouser.
Art
Triad N-68X Tranny for ^SN7 Aikido?Hide this!Advertise here!
WTB: Triad A40-J pabbi1 Swap Meet 0 14th June 2009 03:46 AM
Triad C-14X choke (Simple SE) Ty_Bower Tubelab 3 15th July 2008 05:36 PM
WTB Triad C-47U choke jeff mai Swap Meet 0 28th November 2006 05:34 AM
2 TRIAD filament transformer for sale tecoyi Swap Meet 0 30th January 2005 06:11 AM
TRIAD specs. needed! Fuling Tubes / Valves 0 23rd September 2003 01:56 PM
Copyright ©1999-2017 diyAudio
