6sn7 alternative
6sn7 alternative
Old 8th August 2009, 04:06 AM   #11
gary h is offline gary h  United States
Default whoops
here's the schematic
Old 8th August 2009, 04:30 AM   #12
kmtang is offline kmtang  Canada
kmtang's Avatar
Default 7N7
6SN7 in Loctal base. It sounds really nice.
I use the 7N7's in all my amps and the 6SN7's are in boxes.
Get the 7N7's while they last.
Johnny
Old 9th August 2009, 09:28 PM   #13
kevinkr's Avatar
6sn7 alternative
Originally posted by gary h
Kevin,
I think you and Wavebourn are right, I misunderstand how the anodes work in this circuit. I've attached a schematic of my Aikido PS which includes the heater bias. The audio circuit is JBs Aikido using 4 6sn7s in series. How would you lower the bias closer to the cathode voltage?
thanks
gary
Hi Gary,
Actually I was advocating for a higher, not lower voltage, so go from 70V to 100V, noting that the filament insulation is claimed to be not good for much more than this. (As an aside I do use 6SN7GTA or GTB in SRPP to drive 300B with 400V on the upper anode and I float the filaments for this tube at roughly 100-110V and have not had any failures in 10yrs due to doing this. ) I would change the 300K resistor to 220K in the filament supply bias circuit and see what happens.
I would recommend reducing the 330V to 300V as well on the theory that this will reduce the voltage on the upper cathode by 15V or so and might also help by reducing voltage stress between the filament and cathode in the upper triode of the pair.
One other question would be whether or not the board has grid stopper resistors present.
You don't leave it on continuously like some audiophiles I know, leading both to wasted power and shortened tube life. (?)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 10th August 2009, 03:58 PM   #14
thanks Kevin,
I appreciate the help
gary
Old 10th August 2009, 10:16 PM   #15
MARIANELA is offline MARIANELA  Argentina
6CG7 IS IDENTICAL
Old 10th August 2009, 11:19 PM   #16
DrewP is offline DrewP
For what it's worth, just the same as not all 6SN7's are created equal, not all 6CG7's are the same.
We did some tube rolling a few years back on an MC phono stage with a range of 6CG7's and there was a pretty wide spread of difference in the way they sounded.
Old 11th August 2009, 02:53 AM   #17
Geek is offline Geek
Geek's Avatar
Same variation in 6SN7... I used to deal heavily with them a few years back.
Cheers!
Old 11th August 2009, 10:21 AM   #18
Gordy is offline Gordy  United Kingdom
Originally posted by MARIANELA
6CG7 IS IDENTICAL
Cheers!
There is only one electrical specification for 6SN7, 6CG7, etc.. All 6SN7s are the same, all 6CG7s are the same, and 6SN7 and 6CG7 are functionally equivalent. The difference that you hear is based upon different MANUFACTURING TOLERANCES. Those that are manufactured exactly to the datasheet specification will perform differently to those manufactured at + 20 % tolerance.
Old 11th August 2009, 07:31 PM   #19
sepolansky is offline sepolansky  United States
sepolansky's Avatar
Gary H,
If you are using a Broskie PCB laid out for octals and don't wish to go 9-pin, then the 6SN7 variants are probably the best sounding you'll find. However, many of the highly sought after and good sounding tubes either start out or with use do go microphonic. I have a pair of Sylvania VT-231s that do just that.
I use them in a line stage application (7mA, 150V per plate) and they sound just fine.
The thing that has worked for me are the Herbie's Damping Instruments. You might try them. See what you think. Cheaper than new tubes.
It can also help to mount the PCB onto a piece of acrylic, Delrin or maple (other woods may also work well). Use nylon standoffs, or hang the PCB from springs connected to standoffs using those little eyelets one uses to solder a conductor to a stud.
Good luck,
Stuart
Old 11th August 2009, 07:50 PM   #20
Brit01 is offline Brit01  United Kingdom
That's really cool Stuart.
I see you use red led bias there. How do you find that?
Are you using this for the input and output tubes so you have 1.7V on both?
I'm just beginning to implement this in my designs.
6sn7 alternativeHide this!Advertise here!
SE 6SN7 amp.... JandG Tubes / Valves 25 3rd February 2015 10:36 AM
Help me.......What is the 6SN7 ??????? cd149dc Tubes / Valves 10 17th June 2007 04:09 PM
Is it the 6SN7 or me? arnoldc Tubes / Valves 4 12th October 2006 11:31 PM
6SN7 CCS Cassiel Tubes / Valves 25 14th February 2006 10:09 PM
