| diyAudio Sponsor | ||
I have a colleague visiting from USA and am looking for some good volume pots.
Possibly ALPS. Or something similar. BUT I don't really want to spend more than 10/15 USD on each one. Any recommendations for suppliers in USA? Cheers |
#2 |
Mouser sells the Alps RK27, around $12 I think.
#3 |
Thks. 11.71 USD
What's the RK097? |
#4 |
guys, there are 3 types of RK27 also.:
Snap-In Potentiometers 2-GANG 100K AUDIO Potentiometers Flat 20mm 100k Potentiometers Slotted 20mm 100k What is the difference here? |
#5 | |
Look at the datasheet (there is a link on Mouser) One has a slotted shaft (for a knob or to use a screwdriver for turning) There other has a flat on the shaft to aid in keeping the knob from rotating independently of the shaft when the knob is fastened with a setscrew or a knob with a D-shaped hole. |
#6 |
Thks boywonder.
#7 |
Question regarding a 10K alps I already have.
Lats night I put it into one of my linestage/headphone amps. I'm getting huge amounts of noise when I go anywhere near the metal volume knob and hell breaks loose when I touch it. Do I need to ground the outer casing or what am I doing wrong? I have the third prong attached to the star grounding system. |
#8 |
Just read that I should try connecting the inground connector to the outside casing.
I'll try this when I get home. |
#9 |
update:
Yes it was the unearthed casing on the alps. I connected a wire from the screw to the ground and made it dead silent |
| So I did try all those different potentiometers | Peter Daniel | Chip Amps | 308 | 12th August 2009 02:29 PM |
| potentiometers | zahlm | Parts | 1 | 15th April 2004 05:43 AM |
| Potentiometers | slogan2112 | Solid State | 2 | 19th December 2003 06:54 AM |
| Page generated in 0.08687 seconds (78.66% PHP - 21.34% MySQL) with 10 queries |
