diyAudio Sponsor
Old 5th August 2009, 06:47 PM   #1
syyma is offline syyma  United States
Default Tubelab SSE inrush current limiters.
I'm in the parts ordering for my Tubelab Simple SE build, inrush current limiter (KC009L-ND) just out of stock from DigiKey, lead time will be Nov-6-2009. Can I pick the one with a different value?
There is one from Ametherm, DigiKey P/N: 570-1073-ND but at a higher resistant value. Any recommendations are more then welcome.
Old 5th August 2009, 08:59 PM   #2
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
For use on the transformer primary, those should be fine. For use on the secondary, it might be a little high. Even the CL90 is going to have a fairly high resistance since it is rated for 2A and we draw less than 200mA. Maybe MF72-200D9 (570-1073-ND) would be more appropriate for that location.
Old 5th August 2009, 09:42 PM   #3
Try Allied Electronics for availability. Russ, what is the effect of not installing an in-rush current limiter on the "red/yellow" wire if using a Hammond transformer? Godspeed.
John Revilla
Old 5th August 2009, 09:55 PM   #4
rknize's Avatar
The idea of putting on there is to make the life of the B+ rectifier easier. It limits the current to charge the power supply caps. This is helpful for tube rectification, since current-production tubes don't seem to handle that power-on surge very well when the cathode is still not quite up to temp (causing arcing).
Old 5th August 2009, 10:19 PM   #5
ChrisA is offline ChrisA  United States
Default Re: Tubelab SSE inrush current limiters.
Ametherm will give you free samples. I had them send me a couple dozen in assorted values. (Yes, I really will experiment with them and then spec their part in any design I publish.)
The spec'd KC009L is not really correct for the secondary side of the transformer anyway. There is not enough HT current to heat it to operating temperature. There is good info on the Ametherm web site about selecting the correct part, and you can't beat the price either. http://www.ametherm.com/
I already ask about operating voltage. Their support person said it does not matter as the parts are spec'd by current. I doubt he was 100% correct but our amps don't go into the kilivolt range so I think we will be OK using thermistors across a "mere" 500V
Also if you think about it, placing one of these on the primary side has the desired effect of limiting the B+ current. I'm not sure you even need one on the secondary side. Although there is something to be said for "belt and suspenders" designs
Old 5th August 2009, 10:33 PM   #6
rknize's Avatar
Default Re: Re: Tubelab SSE inrush current limiters.
I suggested MF72-200D9. What do you think?
Not really. The thermistor is plenty toasty from powering the heaters long before the 5AR4 comes up. If you are using SS rectification or if you have a separate transformer for B+, then that would work.
Old 27th August 2009, 09:50 PM   #7
Default Tubelab Simple SE Finished.
Hi All,
I finally finished my Tubelab Simpe SE, up and running for about two weeks.
Many thanks to Tubelab's George who comes up with this great board,reommendation form Russ, ChrisA and John Revilla. Thank you again for all you guys.
Old 28th August 2009, 04:56 AM   #8
rknize's Avatar
Looks nice. Enjoy!
Old 28th August 2009, 02:46 PM   #9
Wow! What a nice looking amp. I like the wood panel execution. I bet this amp sounds excellent as well. Godspeed.
John Revilla
Old 28th August 2009, 08:31 PM   #10
Thank you for your kind words. The frame was made out of red oak from my garage's scraps box. The holes on the side panels are for removed the marks and dings, getting better airflow for the two 10M45 and the board, also easier for me to carry, it's heavy and heavier then I expected. The Hammond steel plate just unable to holding all the irons without sagging, I end up put a strip of maple to support those three transfomers.
This amp sounds excellent with Chinese 6L6GC and JJ EL34L so far, will explore other tubes later, for now I'm enjoy the music first.
Using Inrush Current Limiters hollowman Power Supplies 5 18th September 2008 08:37 PM
Fuses, primary, rails, current limiters and channels? rgrayton Chip Amps 4 5th August 2005 04:15 PM
inrush current Jules Tubes / Valves 8 26th December 2003 05:38 AM
inrush current limiters colden Parts 9 17th October 2003 09:43 PM
About Inrush Current JDeV Parts 0 2nd December 2002 06:40 AM
Page generated in 0.10274 seconds (82.32% PHP - 17.68% MySQL) with 11 queries
