| diyAudio Sponsor | ||
I've been experimenting with various tubes lately and the 12AV7 has a bad reputation in home audio. Maybe for being non linear?
Was curious to see how it sounded. Took some adjustments. First time was awful. But then some tweeks and wow. Playing some Metallica with this configuration really impresses me. Huge presence, power, bass, punch, and more. Maybe the 5687 is better for the softer music, wasn't impressed using this for heavier music. Let me know if anyone want to try this: Some NOS GE 12AV7's. Nice glow also. |
#2 |
My problem with a sleeve of Raytheon 12AV7's is that the filament isn't centertapped
#3 |
ah yes, this also has a line out to use as a linestage. Some RTI 1uF as coupling caps.
#4 | |
#5 | |
Mine too. Same pin out as all other 12A...7 series tubes.
www.kta-hifi.net |
#6 |
Bias question:
I have some yellow led's (2.0V I believe) \ Interested in trying out the led bias system. Could I incorporate in this design easily? |
#7 | |
www.kta-hifi.net |
#8 | ||
12AV7s might be the cheapest 12A*7 type (WHUDDA SURPRISE! ) but there are duals that are even cheaper and more linear as well.Still, if you can get the durn things actually sounding good, then you've really accomplished something. I'm definitely not one to fall for audiophool fads in either tube types or topologies, and have used VTs without any audiophool pedigrees, both in small signal and power applications. Lots of "sleepers" out there that don't command audiophool prices. . Quote:
#9 | |
Slight change in the pin connections on one of the 3 sockets and I'm all ready to go. Would be good to compare. Maybe the power/punch I'm hearing is actually the distortion |
#10 | |
As for how 12AV7s actually sound, that depends on what the distortion profile looks like. Based on a lot of on-line comments, it would seem that these produce mainly h2. "Dark" is how it's frequently expressed, and that means too much h2. You still haven't said how much output this preamp is designed to supply. If it isn't more than a volt or two, the resulting distortion will be less for the lower output swing, will not be excessive, and may be making for a nice effect when playing Metal. |
| 12AV7- 5965 Vs 12AY7 | Trout | Tubes / Valves | 25 | 4th September 2008 09:31 PM |
| Wrong Voltage / current on BoZ... or Wrong Measuring ? | gionag | Pass Labs | 8 | 14th May 2008 11:24 AM |
| what went wrong? | eyekode | Chip Amps | 3 | 3rd September 2007 03:19 AM |
| Where did I go wrong? | Cup of coffee | Solid State | 31 | 26th June 2007 04:26 AM |
| What's wrong with UL anyway ? | percy | Tubes / Valves | 80 | 17th March 2005 03:23 PM |
| Page generated in 0.11535 seconds (80.87% PHP - 19.13% MySQL) with 11 queries |
