| diyAudio Sponsor | ||
I am hoping to design and build a table radio with some rad mono tube sonics. I am thinking of having a fostex driver for a full range sensitive setup. The amp electronics I am thinking of are either that of an s-5 electronics kit bridged into mono for 16 watts or a single ended el84. Since budget is an issue I am thinking that the s-5 is more economical since I already have iron- but something intrigues me to try a simple mono point to point...
Peace!
((AE)) |
#2 |
There are a few simple single-ended schematics floating around on the forum here.. You might want to look into "spud" amps.
Here's a couple links: Spud anyone? http://www.tubeaudio.8m.com/RH84/rh84.html http://www.pmillett.com/midget.htm |
#3 |
I guess an important question I left out is that I am planning on using an FM radio kit like this one: http://www.ramseyelectronics.com/cgi...ction&key=FR1C
It says it has 250mw audio output- could I just tie that output from the board into a tube amplifier and retain the boards volume control? Could it maybe even be used as a preamp stage for an el84? Thanks
((AE)) |
#4 | |
#5 | ||
#6 | ||
Cheers! |
#7 |
Indeed, and any triode-pentode combos such as ECL/PCL series tubes (especially E/PCL82 or E/PCL86) would be a good choice as well for a single envelope amplification up to very decent listening volume level. There are plenty of schematics floating around for these tubes.
#8 |
I like the idea of the spud amp in here- I am feeling the tubelab spud would do well here, or I could point to point it. I am thinking of using some more budget orientated iron to keep costs down and also to save space in the wooden enclosure I am planning.
Although el84's seem to be everywhere and I could probably cram a driver stage in the box... I have heard only good things about the el84. Any favorite simple designs you would recommend to a novice point to pointer?
((AE)) |
#9 |
See, at the bottom of my page, at http://pw2.netcom.com/~wa2ise/radios/feedback.html
#10 |
awesome work man! ...but I don't think that I have the experience to make that happen.
I am kind of thinking about the beauty of the radio, the medium of music transfer, and how much it frees you into music by you just tuning into a list of songs chosen by a DJ- rather than the force within you to pick your own. Although forced to one other persons playlist, we are all forced and that is what is- and so we learn to treat music as not a list of wants and wants but the true-ness of just what is. So I guess I should build this radio then.... peace
((AE)) |
| Designing my very first tube amp... | chops | Tubes / Valves | 15 | 6th November 2006 06:23 PM |
| Help designing a tube amp... | .... | Tubes / Valves | 55 | 18th February 2006 09:50 PM |
| Designing a simple tube opamp? | bradd | Tubes / Valves | 1 | 26th October 2005 06:24 AM |
| Newbie need help in designing tube preamp for my 3886 GC??Please Help me!! | thomgun_lc | Tubes / Valves | 2 | 29th July 2005 06:38 AM |
| Page generated in 0.10940 seconds (79.36% PHP - 20.64% MySQL) with 10 queries |
