| diyAudio Sponsor | ||
I have a question related to grid current. I'm thinking of using a tube at a very low voltage but the only curve that looks more linear at about 20V is when the grid is biased at +2.5V (see attachment, second curve from the left). What are the issues with biasing the grid positive, besides the obvious fact that there's a grid current? I'm a beginner, and any help is greatly appreciated.
#2 |
You're gonna have just esssssssss-loads of distortion. Any sort of Class *2 operation demands a Lo-Z driver that can supply the grid current demand. You didn't specify the type, however, you can find some low voltage plate characteristics Here. It doesn't look like operating at Vgk positive is necessary.
#3 |
You've got two issues- your plan to run the plates at an extraordinarily low voltage and your interpretation of what the ip-vp curves mean.
The first is easy to handle- think three figures. The second is almost as easy- look up "load lines."
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
In my experience:
Tubes are a lot more linear at low voltages than the curves (and popular opinion, old wives tales, etc.) would lead you to believe. You may not need to drive the grid positive. The only way to tell is to experiment. Gm gets very low and Rp gets very high at these extermes, so you will need a high-Z load. A CCS works well. Because of the above issues, don't expect to get any significant power out under these conditions. Voltage amp, yes... Also look at car radio tubes that are designed to run at low voltages. http://www.junkbox.com/electronics/l...agetubes.shtml Pete
When life hands you a jeffery, stroke the furry wall. |
| 2A3 Max Grid Current Rating? | rdf | Tubes / Valves | 0 | 7th July 2009 02:10 AM |
| KT88s and grid current | SpreadSpectrum | Tubes / Valves | 3 | 21st March 2008 07:33 PM |
| 6AS7G with grid current? | Wavebourn | Tubes / Valves | 1 | 16th November 2006 11:22 PM |
| KT66 SE amp, grid current or not? | jhaible | Tubes / Valves | 18 | 25th October 2006 10:56 AM |
| Grid current and direct coupling | jeff mai | Tubes / Valves | 18 | 29th July 2003 11:11 PM |
| Page generated in 0.07372 seconds (70.80% PHP - 29.20% MySQL) with 11 queries |
