| diyAudio Sponsor | ||
I have a regulated tube power supply that I choke loaded. Due to this I need to get some more voltage out than normal when it was capacitor loaded.
It calls for a 0C2 tube which gave me way too low voltage at HV+ output. About 65VDC low. I put in a 0A2 which jumped the final HV+ about 80VDC I need something a little less than the 0A2 so I can set the trim pot with a decent range. Anything between the two of these? |
#2 |
0B2 and the 85A2 spring to mind.
#3 |
If the 0C2 is 103VDC and the 0A2 is 150VDC the something like 130VDC?
I checked the data sheet right now and it list the 0B2 as 108VDC unless I'm reading it wrong? Just found an 0B2 and WOW the highest voltage output yet! OK that won't work. BTW the tube is being loaded with a 30K resistor. Maybe I can change the loading resistor? Its being loaded from the plate (pin 1) of a 12AU7 |
#4 |
Check for neon bulbs and cold cathode thyratrons, they may be in the range you are looking for. One of neon bulbs is used in BC-438 tube receiver I have in my living room currently.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#5 |
Looks like I need a VR tube with a reference voltage of 130V
#6 |
Some of the European STV tubes are around there, like the STV240/40 or STV240/80. Unless you know of a source you may have trouble finding some though.
#7 |
Thanks everyone. I gave up and just changed the voltage divider network. Everything works fine now although one filament supply is running 10 degrees hotter than the other and I'm getting some new noise. Have to look into that.
#8 | |
#9 | |
| Help selecting a DIY amp for... | BlizzofOZ | Chip Amps | 1 | 30th April 2009 09:38 PM |
| Help selecting DIY amp for... | BlizzofOZ | Class D | 2 | 29th April 2009 03:03 PM |
| Help selecting an amp | FBLEAGH | Solid State | 1 | 21st September 2001 05:00 PM |
| Page generated in 0.09399 seconds (78.48% PHP - 21.52% MySQL) with 10 queries |
