diyAudio Sponsor
Old 3rd August 2009, 01:38 AM   #1
hang is offline hang  China
Cool WAHAHA! Our DIY tube amp is done£¡£¡
It take us almost two months to finish the project.Specifically the design of the aluminum alloy shell and three power supply 1mm thick metal shell£¬they spent us a lot of time£¬because the efficiency of factory was too low£¬so we, the working group begin to hate them very much
Now£¬PLS see following pictures
Old 3rd August 2009, 01:40 AM   #2
schematic circuit diagram£º
Old 3rd August 2009, 01:47 AM   #3
Circuit board£º
Old 3rd August 2009, 01:58 AM   #4
Good solder circuit board £º
Old 3rd August 2009, 02:01 AM   #5
above picture£¬because its original image is too big to submit£¬so blurred after compression£¬ I am very sorry about it
Old 3rd August 2009, 02:16 AM   #6
Power Supply£¬you know the power of tube amp is so important,We turn over the electronic market,can not find a suitable power,because the businessmen say they have never been done in this area of power£¬then we look for custom manufacturers
Old 3rd August 2009, 02:18 AM   #7
HA HAHA! Panorama of the TUBE AMP
The front
Old 3rd August 2009, 02:19 AM   #8
the side
Old 3rd August 2009, 02:23 AM   #9
the back
It can take two types of load£¬one for 8 Ohm Speaker£¬Another for 8 Ohm Speaker
Old 3rd August 2009, 02:24 AM   #10
Sorry£¬I did not wake up. Another for 4 Ohm Speaker
WAHAHA! My DIY tube amp is done£¡£¡ hang Vendor's Bazaar 30 1st August 2009 03:40 AM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
Page generated in 0.08836 seconds (75.12% PHP - 24.88% MySQL) with 11 queries
