diyAudio Sponsor
Old 2nd August 2009, 03:38 AM   #1
mobyd is offline mobyd  New Zealand
mobyd's Avatar
Default How to cut ceramic
I have to mount two EF Johnson Jumbo 4 pin sockets (211/845 type) side by side in a space 4 millimetres less than twice the diameter of the ceramic bases of the sockets. Ideally I'd like to shave 2 mm off each side of each socket (I can bend up the connection tabs). Attacking these with the grinder produced much heat and sod all abrasion. Anyone got any idea how to do this ?.
Cheers
M
Old 2nd August 2009, 07:24 AM   #2
dheming is offline dheming  United States
dheming's Avatar
You could use a diamond blade similar to these on your grinder. These kind of blades are used to cut floor tiles so they should work for this.
Old 2nd August 2009, 09:00 AM   #3
chrish is offline chrish  Australia
chrish's Avatar
I am sure that you have thought of this but...
If there is not enough space for the sockets, will there be enough room for the valves? Jones recommends separating power valves by 1 1/2 envelope widths or more. If they are to be close, careful attention to the orientation of the anodes will be required such that the minimum amount of heat radiation is transmitted to the neighbouring valve (oriented so narrow edges of anodes are adjacent and that the larger flat faces of anodes not facing each other).
Good luck!
Chris
Old 2nd August 2009, 09:02 AM   #4
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
even if you have uncut bases positioned so tight , you'll need forced cooling - to prevent overheating of any serious tube .
in other words - they're too near
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 3rd August 2009, 12:38 AM   #5
jjman is online now jjman  United States
Dremel has some "diamond" impregnated cutoff wheels. I usually find the regular cutoff wheels work better on the dremel but I've never tried to cut ceramic with a dremel.
Only diamond worked for me on ceramic floor tiles.
Little help with ceramic cap ID? peace brainerd Parts 1 4th December 2008 08:36 PM
SMD ceramic cap. Which one? antomas Parts 3 12th September 2006 12:05 PM
Ceramic Drivers sdclc126 Multi-Way 12 22nd January 2005 06:11 PM
Need Help Reading Ceramic Cap Value Monolith Parts 9 13th December 2004 02:51 AM
0.1uF @ 3000V Ceramic? MarshallPlexi Tubes / Valves 3 6th October 2004 09:57 AM
Page generated in 0.07224 seconds (70.64% PHP - 29.36% MySQL) with 10 queries
