phrarod said:Thanks for the help!
Here's hoping for no smoke.
Holy smoke Batman !
One last question - on the secondary the HV has three wires. 2 red and a yellow. The input to the power supply has two solder pads. Is the yellow center tap to ground?
I measured continuity between the two red one by one and the yellow and the resistance is the same. So yellow to ground?
- Tubes / Valves
- Trans wires in parallel or series?
